996 GT2/GT3 Forum 1999-2005
Left rear tire wears faster than right side.
Old 01-27-2009, 01:31 PM
datax
datax's Avatar
Default Left rear tire wears faster than right side.
I swapped the R888s for PS2s last weekend and noticed it on both. I had R888s before the current set and same thing. What do you guys think? I've a stock LSD with stock clutch packs in last year. Btw, PS2s never seen a track. Only street drivings.
Old 01-27-2009, 02:18 PM
Rob in VA
Rob in VA's Avatar
Sell the car. It's flawed. Make way for the Z06. I hear they wear tires 100% evenly.
Old 01-27-2009, 02:29 PM
datax
datax's Avatar
LOL! Respect the Z06!!!
Anyway, I remember Mooty posted pictures of his tires once and mine look very similar wear pattern like his. Especially, left rear tire.
Old 01-27-2009, 02:40 PM
va122
va122's Avatar
Mine do that, but i attribute it to clockwise tracks.
Old 01-27-2009, 02:45 PM
datax
datax's Avatar
Here's mooty's thread I'm talking about. https://rennlist.com/forums/996-gt2-...ml#post5601422
Thanks. That also makes sense. But, my PS2 has never been on the track. Unless Rob drove them hard before he sold it to me.
Old 01-27-2009, 02:57 PM
LVDell
LVDell's Avatar
When was the last time you got accurate alignment specs checked? Could be something as simple a one of your alignment setting being off.
Alignment settings (new) and a pic of the tire would really help us to diagnose the uneven wear pattern.
Old 01-27-2009, 03:30 PM
va122
va122's Avatar
Of course! I should have asked about your suspension. Do you have the stock toe links?
Old 01-27-2009, 05:06 PM
datax
datax's Avatar
Haven't done the alignment for a year now. I started using both tires since the stock toe links and the old worn out one from TPC so the wear might have started back then. Local track guys also told me that summit point takes a lot of left rear tires so I'll recheck the alignment/compare and make a conclusion. Thanks guys.
End of discussion.
Old 01-27-2009, 05:08 PM
LVDell
LVDell's Avatar
Wow! No alignment check in a year and you track the car? Ken, get your butt into the shop and get that done more often....that's an order
Old 01-27-2009, 05:32 PM
Bob Rouleau
Still plays with cars.
Bob Rouleau's Avatar
Almost guaranteed to be an alignment problem, excessive toe in or out.
Old 01-27-2009, 07:14 PM
va122
va122's Avatar
You must be waaay out of whack. With the stock links i needed an alignment if i breathed on the car to hard.
Old 01-29-2009, 12:06 AM
iLLM3
iLLM3's Avatar
AGREED, I check mine after each event just to make sure it's all nut and bolted, and because my toe tends to go out (this was with stock toe links).. The links were worn out and the culprit!
Agreed, again when I had stock toe links same thing.. Stil necessary to have it checked after every few events though, I remember my car wouldn't hold alignment well at all , no problem since!
Old 01-29-2009, 08:29 AM
CT03911
CT03911's Avatar
Pretty sure you can swap tires from left to right to even the wear. As a data point I had an alignment done when I bought mine, along with suspension and new toe links.
One year later (the next spring) I had the alignment done again. It had not changed at all.
Old 01-29-2009, 12:00 PM
roberga
roberga's Avatar
I spoke with a Michelin factory rep at the Parade. He stated that they saw it with 911s and from their point of view it is normal for our cars.
Old 01-29-2009, 12:22 PM
datax
datax's Avatar
Good to know. Thank you.
Quick Reply: Left rear tire wears faster than right side.
