Life is good with the GT3 at the track-pics
#31
Chris, the MPSC is going to take FOREVER to get to temp in cold weather so I am surprised you like them so much. They are more of a "deep south" kind of tire.
As far as the Nitto's rubbing, the only place they rub is at full lock and when new. The only place I was ever rubbing was in the paddock getting out to head to the pits!
#32
I sliced the outside rim of the tire with the lip of the fender, and knocked out the side signal light on the pass. side. A little fender rolling at the track took care of it...mostly. As I said, each car will be a little different, depending on what your alignment settings are, and how you got them...shims vs rotation vs both.
#35
The Nittos have slightly different dimensions, so beware. I rubbed with my front Nittos, but not with R6s or MPSCs. I have changed my alignment, and rotated by struts since, so I expect each car will be a little different. I also liked the durability of the Nittos, but thought the grip was not good enough for me to get them again. My difference was greater that Dell's, between the Nittos and R6s, but Mid Ohio does not have as many long straights as VIR, so is perhaps more grip dependent. Nittos are tough enough to drive to the track, if the weather is dry. I also like MPSCs with the GT3. I did not like them with my 993.
Aren't you suppose to be at VIR Audi Event right now? It has been a year since I met you last year.
![](http://i129.photobucket.com/albums/p213/desmom3/gt3_spin_small.gif)
Nice review. Just wanna add that MPSCs are scary in wet. R888s perform night and day difference in the rain compare to Mitchilins. I drive the car absolutely everywhere with those tires on (except in mud). They are very tough as well. Can't wait to try the Nittos.
#36
Datax,
OMG, that is one hell of a slide show. It is amazing how far a car can slide, even when it is under control. You kept the wheel straight and it still did not work, damn phyisic's, you did the right thing and ended up on the wrong end.
I went out on Hoosiers, got all cross-eyed and pulled off before "S" hit the fan. Moisture and a GT3 do not go well together as I figured out all too fast.
Thanks for posting that up, we can all learn from it.
#37
Datax,
![Embarrassment](https://rennlist.com/forums/images/smilies/redface.gif)
Posted some pictures here, https://rennlist.com/forums/showthre...67#post4887167
Esses at VIR are fun in wet...
#38
Cups take a little while to warm up. I've been out in them in less than 10 degrees Celcius. Not sure what that is in F but it's chilly. Once they warm up they are great. Perhaps its that my home track has tremendous grip. Heat cycled out Cups at Tremblant are scary greasy while I can run them to the cords at Calabogie.
Even warming them up doesn't take too long. They are consistent and don't get slippery after 20 min as mentioned above. I tried RA-1s on my S and the Cups are WAY better. Turn in is instantaneous.
I have a new set of cups and some Michelin slicks for next weekend along with my rain Dunlops.
#39
Hey... wait a second... I know that car! ![bigbye](https://rennlist.com/forums/graemlins/xyxwave.gif)
Slicks, Cups, AND rainy day Dunlops? Canuck ain't messin' 'round! Are you going to have another caboose trailer for all those wheels???
#41
Slicks I got free and have about 2 days left on them. They overpower the suspension though. Current Cups are corded so I needed a set of them and if it rains I'll stick better than anybody on the track with the Dunlops. Better than sitting in the paddock waiting for sunshine ...
All fit nicely on the tire rack in the trailer
#42
Even though I don't have my car yet, I have a good time following the track threads.
Got this pic from a friend who is a regular at California Speedway. Recent GT3 crash. Heard he spun on oval and backed into the wall. This was a brand new car.
Drive safely . . . .
![](http://i206.photobucket.com/albums/bb314/glgpc/gt3crash.jpg)
#44
Hey Chuck,
Remember my spin? I made a .gif LOL!
Every tires has pros and cons. MPSCs are fast and consistent if your sessions are longer than 20 mins. You can tell the difference in some DEs where they combine the groups together at the end of the day. R888s can get little greasy. I never had that problem with Mitchilins. But, MPSCs takes longer to heat up so bad for TTs. R888s heats up after braking hard into like 3-4 corners. It's depends on how you use it really.
Damn, another reason I should *not* get GT2 then.
LOL!
#45
Hey Chuck,
LOL!
