996 GT2/GT3 Forum 1999-2005
Traqmate users....do you have the RPM input?
Old 08-03-2007, 09:03 AM
LVDell
LVDell's Avatar
Default Traqmate users....do you have the RPM input?
Here is a link to the part: Traqmate RPM input
If so, where are you tapping into the RPM signal?
I am thinking of adding the Traqvision software but feel it is worthless without adding the RPM input.
TIA!
Old 08-03-2007, 10:00 AM
Camber
Camber's Avatar
I use the DL-1 rather than Traqmate, and get the RPM signal from the wiring harness. If you want to know which wire to tap into, I'll look it up again. Let me know if you're interested.
Old 08-03-2007, 10:10 AM
LVDell
LVDell's Avatar
Thanks Jim, that would be very much appreciated if you could get me that info.
Old 08-03-2007, 10:50 AM
Paul 996
Paul 996's Avatar
Dell,
From another post it was verified to be the following (I happened to save this for my future use) : use pin #9 on the OBD port which is the green/purple wire on MY 04 GT3.
Old 08-03-2007, 10:53 AM
LVDell
LVDell's Avatar
Wow! Thanks Paul. That is beyond specific
See ya at VIR soon
Old 08-03-2007, 01:34 PM
ltcjmramos
ltcjmramos's Avatar
This is from another post (haven't installed mine yet, so don't know if it'll work):
To get a tach signal from a Porche 996 Turbo tap into wire E-6 (Green with blue tracer) from the ECU. This is the No 1 ignition pulse wire and will give a good signal to Traqmate.
This also works for a 997S and may work on most others, at least 996 and newer. The colors are the same on these two, I don't know about others.
There are five plugs into the ECU and E is the last one to the outside of the car, but it's really pretty obvious once you get to the box.
Old 08-05-2007, 11:52 PM
cchan
cchan's Avatar
I can double-verify pin 9 on the OBD port, I've been using it for over a year with my G2X. A lot less risky than playing with DME wiring, in my opinion. Also completely removable if you use an OBD plug - if concerned about warranty.
Old 08-06-2007, 08:26 AM
LVDell
LVDell's Avatar
Pin 9 it is! Thanks so much for everybody's input.
Old 08-06-2007, 10:44 AM
ltcjmramos
ltcjmramos's Avatar
What's an "OBD plug"?
Old 08-06-2007, 11:36 AM
NJ-GT
NJ-GT's Avatar
pictures, please...
Old 08-06-2007, 02:11 PM
v12man
v12man's Avatar
Somethng like this:
[IMG]OBD pcable.jpg[/IMG]
Old 08-06-2007, 02:13 PM
LVDell
LVDell's Avatar
Why would you run that entire assembly when all you need is to tap into pin 9? I can just see my leg breaking that off during a session.
Old 08-06-2007, 02:50 PM
ltcjmramos
ltcjmramos's Avatar
I agree, but how about putting a pin adapter at the end of the rpm device wire to slip onto pin 9?
Old 08-06-2007, 02:53 PM
LVDell
LVDell's Avatar
Probably much easier. Hoping CCHAN posts his pics
Old 08-06-2007, 04:22 PM
v12man
v12man's Avatar
"I can just see my leg breaking that off during a session."
Good point, but there is also a right angle connector that might be better for you.
http://www.obd2connectors.com/Standard-kit.htm
Of course for me it would not be my leg breaking it, it would be the passenger's.
I have been thinking about building a breakout box next to the DME to get access to the sensor's the car already has without cutting in to the harness - baumtools.com make several for motronic diagnostic purposes, and some mods would be needed - similar to a piggyback computer - www.dastek.co.za, but instead of haveing the computer in line, just haveing the connectors to the logger.
That;s going to take a while I fear - got to finish fixing the baby room up first.... LVDELL - your time is coming for that - I have 3 weeks left of freedom.
Quick Reply: Traqmate users....do you have the RPM input?
