996 GT2/GT3 Forum 1999-2005
Nitto NT01....pics and specs before my road test
Old 01-31-2007, 10:27 PM
va122
va122's Avatar
Hey there,
I did not have a pyro and it was COLD and rainy. I dont know how GT3 ran 31/30 (no offence it just diddn't work for me. Cold I can see. I started with 32/34
Very hard to get tires up to temp so to compensate I increased pressure (Thank you Chemistry for once). 42 Hot ( R) is taken when I came off track. About 8 lb increase
The ra-1 users can chime in here, but in my experience with them on my M3 they liked around 40 hot. They had sloppier sidewalls though.
I'll try calling Ntto and some friends who race on them. (Pete you know who I'm talking about) and see what they say.
I'll report back after the weekend but I'm not sure how helpful it will be as the track is almost entirely right hand turns. I run staggered pressures. L/R
Old 02-01-2007, 03:27 PM
Spracar
7th Gear
Spracar's Avatar
I'm interested in hearing how they perform as well...Keep us posted!
Old 02-01-2007, 10:31 PM
gt3-4me
gt3-4me's Avatar
i ran the fastest times at 32/30. i just experimented with pressures to what gave me the best grip and lap times. also gt3bob ran similar pressures when he had his gt3 with nitto's. this was at spring mountain motorsports ranch. not really a high speed track, more of a technical teaching track.
Old 02-03-2007, 01:45 AM
Larry Herman
Basic Site Sponsor
Larry Herman's Avatar
Hey Dell, I think that we will be bringing a few sets down to VIR for my boys to run on their 951 & 993. They look good to me, and hopefully will be faster than the RA1s.
Larry Herman
2016 Ford Transit Connect Titanium LWB
2018 Tesla Model 3 - Electricity can be fun!
Retired Club Racer & National PCA Instructor
Past Flames:
1994 RS America Club Racer
2004 GT3 Track Car
1984 911 Carrera Club Racer
1974 914/4 2.0 Track Car
CLICK HERE to see some of my ancient racing videos.
Old 02-03-2007, 08:49 AM
LVDell
LVDell's Avatar
Sounds good Larry, we'll have to make sure and compare notes over the weekend to fine tune the pressures. I'll have one event on them before the Zone2 DE so I should have some good data collected by then.
Old 02-05-2007, 12:36 PM
Phokaioglaukos
Phokaioglaukos's Avatar
Dell, did you compare the spec sizes of those to the RA-1s? The 315 rear RA-1s rubbed under heavy compression for me with about -2.5° of camber.
Old 02-05-2007, 12:54 PM
LVDell
LVDell's Avatar
Chris, the RA-1's rubbed because they are 35 series tires. The NT01 is a 30 series tire as it should be in the rear of the GT3. I posted all the spec sizes in another thread over in the Racing and DE forum ( https://rennlist.com/forums/showthre...7&page=3&pp=15 ) see post 37. The RA-1 in the 35 series is a FULL INCH taller in inflated diameter hence the rubbing.
ps. did you forget about that thread? You were active in it.
Old 02-05-2007, 01:41 PM
Phokaioglaukos
Thanks, Dell. It's been busy at work for a while now. The rubbing I got with the RA-1 315s was on the side of the sidewall. I will be eager to hear how you fair at your first event. I'm thinking of the spot just pat the bridge on the Shenadoah Circuit at Summit Point where I get all four wheels in the air. I would not want to hear rubbing as the car comes down there.
Old 02-05-2007, 01:59 PM
LVDell
LVDell's Avatar
Sure thing Chris. I will have my update after my 1st event (CMP) and my 2nd event (VIR) next month.
Old 02-06-2007, 11:30 AM
LVDell
LVDell's Avatar
Just an update on the tire pressures. I just talked to a tech at Nitto Tire and he stated that the NT01 will perform best at an optimal temp of 40 hot. I am going to shoot for 38-39 in these tires. I still don't feel 40 is the target number but I could be very mistaken. Only way to find out is to run them and test the temps after each session as well as feedback at different pressures. But one thing is for sure, 30 hot is way too low. Not sure how you (GT3-4ME) ran your fastest times at 30 but then again, every car is different and you have data from you and another at that pressure.
GT3-4ME......did both you and Bob run the NT01? What sizes did you run?
Old 02-06-2007, 11:37 AM
va122
va122's Avatar
I used 36 hot all around with good results. Way too much roll over with 30-31.
Weird though I got quite rubbing on my front Right. Even with rolling the fenders. Also on 3/4 lock the tire will rub the inside liner. We jacked up the ride height a few mm and that seemed to solve it.
I'm using shims to get 2.6 camber up front. Think this increased castor to the point that I'm rubbing the lining or th track was increased hence the rubbing on the sidewall.
Any thoughts?
Old 02-06-2007, 11:47 AM
LVDell
LVDell's Avatar
Not sure about the rubbing since I do not have first hand knowledge and wont till next month. I am taking my car into the shop in the coming week or two to get the alignment set, etc. more for these tires and the track.
I will definitely comment when I get everything taken care of and have a couple track days to get good data. Just a newb here on the R-Comps
Old 02-06-2007, 10:07 PM
gt3-4me
gt3-4me's Avatar
dell bob and i used the same sizes 245 front and 305 rear. i think you guys are right about tire pressures. i ran 32 front and 34 rear this weekend and had good results. i may try higher pressures to see how it works. the good thing is i may get better lap times out of this.
Old 02-06-2007, 10:09 PM
LVDell
LVDell's Avatar
Just to make sure we are talking about the same tires, you are running the NT01 correct?
Also, did you mean 315 not 305?
Old 02-08-2007, 12:27 AM
gt3-4me
gt3-4me's Avatar
yeah 315, i get mixed up with toyo's.
Quick Reply: Nitto NT01....pics and specs before my road test
