Testing our the Nitto NT-01's on two nearly consecutive track days
Old 01-07-2007, 10:24 PM
  #31
karlooz
karlooz's Avatar
Originally Posted by LVDell
According to the Nitto Website:
Looks like 245/40/18 is for a rim size 8"-9.5" with an optimal rim of 8.5" so we should be great on the 8.5" factory rim
and the 315/30/18 is for a rim size 10.5"-11.5" with the optimal rim of 11" so we should be great on the 11" factory rim
hope that the 315 is a "narrow" 315 otherwise you might have to do some fender rolling. i recall someone with a gt3 (maybe dc lee?) tried out the 305 toyo ra1s and they didn't fit.
Old 01-08-2007, 01:39 AM
  #32
multi21
multi21's Avatar
Received 3,340 Likes on 1,978 Posts
I have definitely heard of the 305 RA-1's rubbing on the rear fenders of the GT3. Others say not, but it's probably borderline without rolled fenders.
Old 01-08-2007, 02:23 AM
  #33
va122
va122's Avatar
You know, I've heard no problems with shaved ones.
Old 01-08-2007, 08:31 AM
  #34
Phokaioglaukos
Phokaioglaukos's Avatar
That was me. They only rubbed on serious compression (there is a good dip between the shop and my house on one route), but that would happen at Shenandoah, for example, so I moved down to the 275s.
Old 01-08-2007, 10:38 AM
  #35
Chris L.
Chris L.'s Avatar
Have you tried the Nittos? So I gather that you would recommend the 275s as the 315 Nittos would seem to wide?
Old 01-08-2007, 10:44 AM
  #36
LVDell
LVDell's Avatar
I am going to check into the tire's width and and inflated diameter and compare to the 295 PS2's I have right now. I have no desire to go DOWN to a 275 from a 295 if I do not have to.
Old 01-08-2007, 10:51 AM
  #37
LVDell
LVDell's Avatar
O.K., so here's the spec on the tires:
Michelen PS2's currently on the car:
ID-->25.00 Width-->11.90 Rev/Mile-->832
MPSC (non-shaved):
ID-->25.20 Width-->12.10 Rev/Mile-->833
Nitto 275/35:
ID-->25.55 Width-->10.91 Rev/Mile-->813
Nitto 315/30:
ID-->25.35 Width-->12.60 Rev/Mile-->819
ID=Inflated Diameter
Old 01-08-2007, 10:58 AM
  #38
Chris L.
Chris L.'s Avatar
MPSC (non-shaved):
Nitto 275/35:
Nitto 315/30:
So the verdict is what for you?
Can we work these 315s?
Old 01-08-2007, 11:17 AM
  #39
LVDell
LVDell's Avatar
Considering that the inflated diameter is only .35" more and the width is .7" more I am thinking there should be no problem at all.
Taking into account that the width in only .7" that is not a full .7" on the outside but rather the ENTIRE contact patch and in "rough" math terms that is only .35" extended to the outside (as well as .35" to the inside). So, .35" out and .35" up (ID) I can't see any reason why there would be rubbing issues.
But for the street, I would say no.
Old 01-08-2007, 11:19 AM
  #40
LVDell
LVDell's Avatar
All I need now is to find out what Nitto rec'd as tire temp and camber settings.
Old 01-08-2007, 11:23 AM
  #41
Chris L.
Chris L.'s Avatar
You da man!!!
Thanks for the "hours and hours" of research. Actually I am serious. Thanks.
Old 01-08-2007, 11:35 AM
  #42
LVDell
LVDell's Avatar
Not really hours, but let's go with that
Now if I can just get a hold of the temps and cambers rec'd we'll be good.
Old 01-08-2007, 12:09 PM
  #43
Phokaioglaukos
I have not seen the Nittos. The contact I had with the RA-1 305/35R18s was that the sidewall would touch the fender edge on serious compression, such as when the car got air. The Toyo web site says the 305s have a 12.5" overall width when inflated.
Old 01-08-2007, 12:23 PM
  #44
LVDell
LVDell's Avatar
Serious compression? Air? Damn! That is some spirited driving
What camber are you running in the rear? What about ride height?
Old 01-08-2007, 12:35 PM
  #45
Phokaioglaukos
Stock ride height: 115 + 5 mm (115 to 120 mm) front and 128 + 5 mm (128 to 133 mm) rear. Rear camber, where the rubbing occurred, was -2°.
At Shenandoah I get air under all four wheels after coming under the bridge at about 120+ mph.
Quick Reply: Testing our the Nitto NT-01's on two nearly consecutive track days
