996 GT2/GT3 Forum 1999-2005
What is the correct / best RMS to use gor track car?
Old 10-01-2017, 10:20 AM
rbahr
rbahr's Avatar
Default What is the correct / best RMS to use gor track car?
Been looking and what I most see is just 'change it when you can'...
996 or 997 , gt3 or tt or ???
P/N would be great as well...
Ray
Old 10-01-2017, 07:16 PM
AudiOn19s
AudiOn19s's Avatar
I put the 997 turbo seal in mine as did a good friend of mine. It makes an annoying chirping noise that you will hear if your car is quiet...but it doesn't leak. I can only hear it at idle in my car. Did I mention it doesn't leak? :-)
Old 10-01-2017, 10:49 PM
rbahr
rbahr's Avatar
Thanks,
That would be P/N 999.113.426.41?
Do I also need spacer ring P/N 997.101.264.90?
Ray
Old 10-02-2017, 09:30 AM
AudiOn19s
AudiOn19s's Avatar
Originally Posted by rbahr
Thanks,
Ray
I hate to admit this since I take pride in doing all of my own work...this was the one instance where I didn't do the work myself on my car. I had 1 week to get the thing fixed and outsourced the work to my local trusted shop, asked them to source the 997 TT seal and let them do their thing.
Sorry I can't confirm!
Old 10-02-2017, 10:52 AM
rbahr
rbahr's Avatar
You slacker you
The number I posted is shown to support the 997TT, BUT there are about 3 numbers for GT3 compatible RMS's hence the confusion.
Ray
Old 10-02-2017, 01:46 PM
993GT
993GT's Avatar
isn't exactly direct comparison (RPM's), but my GT2 (7200rpm redline) is bone dry on its GT2/TT RMS
Last owner did a clutch/flywheel, RMS was done then- has travelled 75,000km since then, 67k of them being with me
Old 10-02-2017, 01:51 PM
rbahr
rbahr's Avatar
Do you have the part #?
Ray
Old 10-08-2017, 06:11 PM
JasonAndreas
Technical Guru
JasonAndreas's Avatar
Isn't the deciding factor for RMS selection whether or not you are running a vacuum in the crankcase?
Old 10-08-2017, 10:30 PM
rbahr
rbahr's Avatar
Perhaps, but there are a number of parts for under a vacuum or not. I ended up going with not - I guess I should check to see if the vent has been upgraded.
I pulled 997.102.264.91 out of the motor... I have the 999 part waiting to go in - need to build a tool 1st to not muck things up...
With all the different parts, I as hoping that there would be a simple definitive answer...
Ray
Quick Reply: What is the correct / best RMS to use gor track car?
