What Failure Diagnoses Require Engine Drop/Glitter in Oil
#121
"Reputable shops"...maybe Yes, matbe No.
Many "reputable shops" are, well, reputable. But....their techs are NOT engine re-builders. Faced with unexplainable metal fragments, such shops frequently gravitate to their 996 Porsche biases, like "its the IMSB".
Engine re-builders, like Flat 6 and a few rennlisters, are "technicians with actual engine repair experience".
relinuca
relinuca
#122
1000 dollar question, My dual row IMSB seems to be in perfect condition. Seal looks good turns and smoothly, no play. I am thinking of just putting the IMS back in the car as is. Then replacing it at 60k when I do my clutch. I can't think of any reason to put in a non sealed bearing now with engines history of making metal. I plan on having two magnetic drain plugs and just swapping them out every 2k miles or so just to check for any ferrous metal particles.
#123
BTW, how did the thrust surface on the crankshaft look?
#124
Received 1,093 Likes
#125
Shafts sitting on the bench with the bearing still in place. I am considering getting the shaft pinned but really don't have a local machine shop here in San Diego I know to do it.
Just going to send it to LN to have it done.
#126
#127
Is it worth the risk?
#130
Case halves together, kinda a PITA getting the first two wrist pins in........ Clips went in great even with the tab left on.
#131
I wish I could do this!
Glad to see things moving forward for you and thanks for sharing the process...
#134
Heads on and timed. Bought a cheap angle torque tool for the head bolts that worked good enough.
Accessories going on, waiting for replacement heat exchanger, old one was pitted on bottom due to leakage. I was worried it wouldn't seal. Machined surface on case where o-rings sit are slightly grooved still after factory machining so might not have been making a good seal.
#135
