My "New to Me" wheels
For the front, the recommended offset for 19" / 8,5 is 55 mm. my set up had a 50 mm offset so yours having a 45 offset so again will project out an additional 5 mm than mine and 10 mm than recommended. You will not know until you have tire mounted and installed on car so as to check wheel well splash guard for rubs at full turn. Keep in mind that the 235/35/19 front tire is a bit bigger in dia than OEM (do a tire comparison on google).
Have you considered the Titanium lug nuts? Acer has them for $199 a set of 20 and they also make them in black. I got there set with the optional lock lugs and they worked and look great as well as saving approx .4 lbs per wheel on unsprung weight. In addition, it looks like they have now been approved for track use. Much better price than those $800+ sets you may of seen on other sites.
https://www.acerracing.com/ball_bear...-1701-128.html
