996 Forum 1999-2005
Hows my car stuff look?
Old 05-22-2017, 02:22 AM
Chris(MA)
Chris(MA)'s Avatar
Default Hows my car stuff look?
Here are some pics of my IMS and RMS, also my flywheel. My clutch plate was in pretty good shape for 102k miles but obviously I'm putting a new clutch kit on anyway.
My flywheel is smooth and seems ok, has some slight discoloration. I assume the spring kind of rotation thing is the dual mass in action?
I think I have an oil cooler leak, should I just replace the whole thing?
I also think my AOS has gone, at idle I get quite a suck when I take the oil cap off and from the pic here it looks like its gone.
It looks like I have a dual row IMS.
Old 05-22-2017, 11:19 AM
fpb111
fpb111's Avatar
At 107k I would replace the flywheel also.
The corrosion in the cavity under the cooler is normal. It is not caused by a cooler leak. Moisture gets in that cavity through the opening at the top and works on the case as it sits there and slowly evaporates. Impressive that you have what appears to be a DRY original RMS.
Old 05-22-2017, 02:12 PM
Chris(MA)
Chris(MA)'s Avatar
Why would I have to change the flywheel? I was about to order a new oil cooler and O-rings, should I just leave this instead? it would save me time and money not swapping out the oil cooler right now.
Thanks!
Old 05-22-2017, 02:19 PM
Cuda911
Cuda911's Avatar
I would replace the AA battery for your flywheel. Looks dead to me.
Old 05-22-2017, 02:31 PM
johneecatt
johneecatt's Avatar
As you probably know, Porsche Racing is huge into electric power now - and word is they make a AA flywheel battery with a 15 year life...!!
Old 05-22-2017, 02:34 PM
Chris(MA)
Chris(MA)'s Avatar
I read more about the flywheel...eeekk does everything in this car have 100x times more parts than it needs to have, do germans not know how to design KISS..?
Looks like there is a rotation spec of 20mm on the flywheel, I will check it when I get home.
Regarding the oil cooler, should I leave it or should I replace? I got the transmission out now, I need to pull the trigger on my next parts order to make it in time for the memorial 3 day weekend.
thanks guys
Old 05-23-2017, 12:19 AM
Always wanted 1
Always wanted 1's Avatar
No
Old 05-23-2017, 01:21 AM
johnireland
johnireland's Avatar
You've got it all apart, just change everything and know that you're good for another ten years.
Old 05-23-2017, 09:04 AM
DBJoe996
DBJoe996's Avatar
Received 1,192 Likes on 762 Posts
Looks like you have a good plan for the clutch components. I would replace everything clutch related, including the DMF. Don't forget new flywheel bolts. Definitely time for a new AOS. The oil cooler has some O-rings underneath, but, if it is not leaking then I think I would leave it alone. Jake has stated that when replacing the oil cooler he has found many that are warped out of the box. That means another engine drop just to fix that.
Old 05-23-2017, 09:36 AM
AWDGuy
AWDGuy's Avatar
i wouldnt change the flywheel
Old 05-23-2017, 11:23 AM
Chris(MA)
Chris(MA)'s Avatar
update, i bought 2x 6 ton jack stands for the rear, its more stable now. my DMF is in very good shape, minimal sag so im reusing it, the guy seemed very light on his clutch PO. Putting new AOS on but leaving the oil cooler.
i cant find instructions on changing the AOS from the back side\underneath, im assuming its possible. i oredered a dual row LN IMS for replacement.
Old 05-23-2017, 12:55 PM
5CHN3LL
5CHN3LL's Avatar
My one regret when I did my clutch and IMSB retrofit was not getting a new flywheel. It's now in need of replacing; it would have been so much cheaper to have not been cheap in the first place.
Old 05-23-2017, 01:09 PM
Chris(MA)
Chris(MA)'s Avatar
What condition was it in when you took it out though and the general clutch? the PO of my car seemed very gentle on the clutch, if I had to guess the car was garaged all week and used for long drives at weekends. Here's a pic of a new clutch plate Vs the old one, there is wear but seems very good for that kind of mileage.
I drove a bunch of 996's before I bought this one and even higher mileage ones seem to have no issues with the clutch, I get the impression if you drive it conservatively the DMF is a long lasting part.
Old 05-23-2017, 10:06 PM
dan_189
dan_189's Avatar
I'm in the replace the flywheel camp but seeming you've already dropped the transmission yourself you could just as easily replace it at a later date. Although you should do it now seeming you've come this far.
Old 05-24-2017, 01:04 AM
texcwa
texcwa's Avatar
After buying my 2004 C2 I immediately took it to my Indy shop for the IMS and RMS upgrade at which time they told me that I had approx 40%- left on clutch and recommended replacing since they were into it. They also recommended replacing the flywheel each and every time a clutch replacement is performed. Even though that meant another $900.00, I trusted that they knew more than I so had it done.
Quick Reply: Hows my car stuff look?
