P72 Option Code
Pretty sure it's a "bundled options" code. My master spreadsheet (which I think is for USA cars only) does not have the code for P72. I only have these:
P73 Option package incl. 551 680
P74 Option package incl. 288 601
P77 Option package incl. 375 376
Someone from the other side of the big cold pond will need to chime in... Sorry.
found in another forum
"... the 1999 996 is the only model year 996 with a locking (limited slip) differential--which apparently uses Anti-Slip Regulation and Automatic Braking Differentiation as a package dubbed "Traction Control"--order code P72."
A limited slip would be a nice bonus.
Any way to confirm this other than jacking up the rear and rotating the rear wheels?
219 Regular differential (without limited slip)
220 LSD Limited Slip Differential
222 Traction control ASR AntriebsSchlupfRegelung
224 Traction control ABD Automatic Braking Differential
P72 probably = 220, 222, 224
You can go to a Stealership and get the full build sheet for your car, which shows everything "else" that doesn't make it onto the sticker inside the hood.
