996 Lug Nut Key
If you have spacers you'll need longer lugs.
Sadly there is no "local dealer" per se where I am. Tried a bunch of "Porsche Service Centers" but none have the key set I need. I have the Porsche 5mm spacer kit installed which came with slightly longer bolts and a "spline" type locking key which is different from the OEM Porsche key with teeth. Suncoast sells the 5mm longer bolts à la carte for $9 each - I think that's the answer. Hammer and replace, or would I be okay with one slightly shorter bolt out of the five on one wheel (for now).
Trivia time:
New OEM wheel bolts appear to have been painted silver. This coating is actually a special anti-seize compound good for "first application" only.
In other words, don't apply anti-seize to threads when initially fitting new bolts.
relinuca
relinuca
If you have the OE wheel locks, they are pretty simple to remove with a 11/16" (12 point) socket.
I had the same issue and posted about it here:
https://rennlist.com/forums/996-foru...-key-easy.html
Apply a thin coat of Optimoly TA (aluminium
paste) on the thread and between the bolt
head and movable spherical cap ring (arrows).
The bearing surface of the spherical cap
facing the wheel must not be greased.
