HAVE MILSHAKE
#91
Not really..many shops (service managers) think a PPI and CPO inspection are/should be the same thing, and price them the same (2.5 hrs). This of course does not include a extensive (8hr) engine analysis. Every car that came in our shop got a 25 point safety inspection whether it came in for a battery or oil change or turn signal bulb.(25 point safety inspection includes tire pressure, tread life ,brake life, fluid levels ,check for leaks, wiper blade life, all lights, horn, ect). CPO inspection is very detailed (but not engine analytic, just engine smoothness, noise,leaks, codes,overrevs) check list from Porsche for specs for tires, brakes, scratches per panel, paint repair ,(check paint thickness).fit and finish. A very exhaustive check list to be done in 2.5 hrs. CPO inspections are usually done on cars only a couple years old. There is a big difference on doing an inspection on a 2 year old 911 with 6k miles, and a 15 year old 911 with 110k miles ! A 2002 911 should indeed take 8 hrs to do a proper inspection to get a good indication of the future of the car.Throw in a buyer that wants a "good deal" and a seller that wants to sell a 110k mile 911 for "whats it's worth" it's not easy money and can be a big hassle. Unless i knew either they buyer, or the seller, or the car personally I hated doing PPI's.
#92
The higher the liability the less desirable the PPI is for the shop. An extreme case is guy looking at a 2 million dollar Ferrari. The shop believes they did a first class PPI but the buyer ends up needing an engine rebuild not long after. It can get ugly real quick with lawyers being retained on both sides (its happened many times).
Want a PPI on that 2008 Camry? Plug in the OBDII, give the tech an hour to go over the car and you're on your way for an hour's worth of labor.
#94
Shameful Thread Killer
The PPI business is kind of no win. Either the seller will be pissed because you **** raped his car, or the buyer will be pissed that you missed something and the car comes apart after sale which will now forever be referred to as - MILSHAKE issue.
#95
Former Vendor
Yep, the PPI is risky business for a shop. They stand a high risk of pissing off the buyer by telling the truth, or the seller by telling the truth. Either way, in most cases any car that has an issue is going to have one of the parties involved being pissed at the results.
As for shops doing sublet work, it happens all the time. Shops try to do this with us, sending us cars for specialty work. I refuse to deal with another shop, I want to work directly with the owner, and won;t have it any other way.
#96
In the aviation world, we many times use the required annual inspection as the go forward point for a PPI. The annual insp is a detailed look at a plane to insure it meets the standards of the mfg in all cases, except the additions or changes made via a Supplementary Type Cert detailing accepted changes and alterations to the plane as it was mfg.
There are also documented minor alterations that must be checked as well. In the car business they would be something like adding Al pedals, or changing the seats. But - the minor alterations have in all cases been approved by a FAA qual inspector, and filed with the FAA. However, having said that - each individual inspector has different levels of determination on what 'meets the type certificate' actually means. So, there's always some wiggle involved.
#97
#98
I'm sorry, that's "2 parts silicone"....or is it "2 silicone parts", I always get that confused.
#99
The amount of checks etc an aircraft goes through was fascinating.
Sorry, VERY FASCINATING! -> Caps just to keep the theme of this thread going.
#100
PROVOCATIVE MISSPELLS BY CAPS USING FIRST AND SINGLE POST USERS.
1. C chunk
2. Boar Smoring.
3. Intertwix
4. Chain Prattle
5. Spam Deviation
6. Thrust Watcher
7. Air Oil Accumulator
8. Intermediate Shaft Fairing
9. PPeye and seal degrade install courtesy of below.
Prequalify.....what???
1. C chunk
2. Boar Smoring.
3. Intertwix
4. Chain Prattle
5. Spam Deviation
6. Thrust Watcher
#101
11. Remedial shift baring
12. Remained Seal
13. Post Purchase Infection
#102
Post PUrchase Infection is the worst....that's when you definitely know you got screwed by the seller.
#105
