nor Indy or dealership could fix it I need you guys help!!!
#76
Former Vendor
I know whats wrong with it.. Throw it on a truck and ship it on down. If I can't repair it- you don't pay me.
I haven't had one yet that I couldn't repair, but some have taken months to figure out. That said, within one hour I'll tell you if the engine has a mechanical issue with two sets of data being collected.
To clarify any comments I have made here about lifters:
Lifters can give issues with these engines, but when they do so they typically do not make "noise" that is usually associated with a bad lifter. Those noises are almost always misdiagnosed as a lifter issue, when they are actually cylinder issues at early onset. My comments about lifters not giving problems were obviously perceived differently than I intended by some members of this board.
I have had two lifter issues in the past month, neither made noise, and one of those came from a bad set of genuine Porsche lifters right out of the box.
In short, the things that are usually "lifter problems" with other engines don't show up the same way with an M96/ M97 engine.
#78
Received 1,090 Likes
#79
At this point, I'd take Jake up on his offer, you have nothing to lose!
#80
Former Vendor
#82
Former Vendor
We ship so many Porsches that I've started a separate division here to handle shipping brokerage and have a dedicated employee to handle this. I can have Randy at P- Car shipping contact you. Our best shipper runs the NC, SC route with a single car enclosed trailer. Jeff never disappoints with his services!
#83
You need to connect a vacuum guage to manifold vacuum ,set it up inside cabin
so you can monitor it.When the miss occurs ,If the guage fluctuates rapidly its
mechanical.If the guage stays steady its electrical.The reason your indy and
dealer techs had no answer for you is because the miss fire did not occur
when they were testing it.You need to monitor the vacuum when the miss
occurs.I worked for ford dealer for 32 years ,a senior master in gas and diesel
and alt fuels.I have seen concerns like this many times.You want to do non
invasive tests first.This is your most basic test that will give you a direction to
diagnose the concern .You already know which cyl it is.Its not a valve timing
problem because that would affect half the cylinders.One of hardest concerns
to diagnose erratic problems ,even with a code generated.Save yourself time
and money do this simple test before going into invasive diagnostics.If its elec
perform diagnostics per shop manual.I have set up diag equpt set to auto
record selected data ,have the customer drive it until concern happens,then
download and read data.
#84
i had a cyl 6 misfire that would only occur at idle or low RPM's. i had a p306 misfire code and a camshaft deviation bank 2 code (p1342 if i remember correctly) the codes would pop up at different times. I replaced the lifters and camshaft tensioner/pads and the misfire hasn't returned nor has the deviation code.
#85
<< Wondering what the prognosis is on the OP's car??
#86
Well Guys the 911 is finally Fixed... woohoo!!!! I went ahead and parked the car for several months in order to figure out what I was going to do with the 911, so early this summer I took my 1973 Mazda Rx2 to a cars and coffee, and there was this guy with a Bad a$$ 911TT, I approached him and explained the problem with my 911, he told me that he can figure out the problem, so after talking about his 911TT and my Mazda Rx2, I found out he is the owner of HBI auto in Mocksville NC, They specialize in Porsche, Lamborghini and Ferraris. I agree to let him take my 911, the next day he came up to my house with an enclosed trailer, we loaded up my 911. About a moth later he called me and told me he found the problem, I was super excited, so I agree to have him fix the issue and it was 2 bad lifters in Cyl #2. So yes Flat6 Innovations was correct. Once the 911 was completed and running like a 911 40th AE is supposed to he delivered the 911 back to my house at no cost for the pickup and delivery. I drive my 911 everyday and everywhere I go. Im HAPPY !!!! Thank you to Billy @ HBI Auto in Mocksville NC https://hbiauto.com/
#87
Awesome! What did the repair cost?
#88
#90
