Thinking of selling my 996. Hope you don't hate me
#32
#33
You know darn well I'd only get to drive it on the weekends as Ang would want to be the "owner".
#34
Yeah, I don't think I would describe it as strong in its stock form. More like good enough for DD coupled with a few out right poor design choices that can be addessed with better quality aftermarket components. You just don't get a feel of over engineering if you look at the engine parts closely.
#35
#36
This condition was created by and is perpetuated by Porsche. Building and selling M96 engines (or a more modern version backward compatible with the 996) at a reasonable cost would take the legs right out from under all of the 986/996 engine problems. Despite the Porsche spam they mailed me about the 996 being a classic, not having a crate engine program shows that Porsche has no genuine interest in making a long-term commitment to the 996 community.
#37
Noooooooooooooooooooooooooo...........
#38
True, but when you replace the Ferrari engine the car is worth more than the engine, a lot more. When you replace a 996 engine...well, you have a new engine anyway.
My 2002 996 with 121,000 miles has needed expensive maintenance due to wear items, which is expected, but otherwise no problems. But I would never, ever, invest $25k for a "done right" engine in this car. I would immediately move up to a 997.2 or 991. I can get a 2013 911 with PDK and 30k miles on it for $58,000 today. And if I could get $15k for my car on trade (I can't) I would do it.
#39
I was at the same point as you are .Really liked the platform but did not trust the engine -even after LNE IMS kit ,new cam chains and pads , AOS and a lot of other stuff .I could not get past the parts and machining costs if the engine let go and if it ate a crankshaft then it was just absurd .
My solution was a LSX swap -not perfect but reliable .
#41
They is me -no kit .The only gauge that does not work is the oil level .The Porsche ECU controls all non engine functions .The gm E CU controls engine and emissions using the Porsche purge valve and evap componets .This is a 1999 996 which is pretty basic .Don't know about the newer models.
#42
Here are a few of the California Air Resources Board (CARB) guidelines for engine swaps. It becomes obvious fairly quickly that CARB does not want you to swap a V8 into a non-V8 car...
The extent to which CARB tries to sabotage engine swaps just sucks.
- "Engine and emission control systems must be in an engine-chassis configuration certified by the California Air Resources Board (ARB) or U.S. Environmental Protection Agency (EPA)."
- "The installed engine and host chassis must retain all of their original emission control equipment."
- Voiding the vehicle manufacturer's emission warranty is not allowed.
- Mixing and matching emission control system components could cause problems and is generally not allowed.
- ...state and federal anti-tampering laws generally prohibit any modification to the vehicle's original emission control system configuration as certified by the manufacturer.
#43
ontario has similar rules and it's why I didn't go down that road when my motor went. it was the same cost also and lot more work outside of my domain.
we're also legalizing weed apparently.
#45
I was at the same point as you are .Really liked the platform but did not trust the engine -even after LNE IMS kit ,new cam chains and pads , AOS and a lot of other stuff .I could not get past the parts and machining costs if the engine let go and if it ate a crankshaft then it was just absurd . My solution was a LSX swap -not perfect but reliable .
