996 Forum 1999-2005
Gas Monkey LS Powered 911
Old 10-26-2016, 04:32 PM
  #61
jasile
jasile's Avatar
Richard seems a little smarter than OCC. I don't think he is going to go that way. Too diversified.
Old 10-26-2016, 05:19 PM
  #62
RMG
RMG's Avatar
Originally Posted by jasile
Is it even practical from a future servicing of the engine perspective (i.e. can you even get to the oil filter without dropping the engine?). Additionally, what does the Chevy V-8 do to the weight balance and handling.
But trying to squeeze a V8 ( …albeit not a Chevy, that is heresy) into a 911 rear end is not a new idea. RUF has built a V8 from scratch for their RGT model. The rumor has it Porsche AG was considering doing the same but has abandoned the idea.
Old 10-26-2016, 05:35 PM
  #63
jasile
jasile's Avatar
That V-8 looks a lot better than the GMG one. A V-8 that is purposefully built to be installed into the 996 I can understand. It is a deliberate effort. The GMG effort, although they had adapters and so forth, seemed like an experiment. But, hey, they did it and sold it on, so good on 'em.
Old 10-26-2016, 05:46 PM
  #64
m3driver
m3driver's Avatar
hahahahah! The GM ls series motors are hands down some of the best motors ever produced, and with no question are better than any motor Porsche ever even thought about
Old 10-26-2016, 05:55 PM
  #65
jasile
jasile's Avatar
"and with no question are better than any motor Porsche ever even thought about"
Knowing what someone else is thinking is exceptional and uncommon insight. hahahaha
Old 10-26-2016, 06:01 PM
  #66
5CHN3LL
5CHN3LL's Avatar
I wouldn't necessarily say that the LS is the best motor ever designed, but the pushrod design, although much maligned by the DOHC community, allows for some useful geometry. Example: Using the area between cylinder banks for camshafts and pushrods means the engine package doesn't need to be as tall as many overhead cam designs. In applications (like the Corvette) where there needs to be both adequate ground clearance and a low c/g, this works very well.
Raise the limiter on an LS3 engine from 6600 to 8200RPM and run it that way for a bit...then come back and explain how it is superior in every way to a Porsche engine. Your apple is neither better nor worse than my orange; just different.
Old 10-26-2016, 06:54 PM
  #67
RMG
RMG's Avatar
.. good for up to 8200 rpm and the engine sound is absolutely sublime. Check out this video showing the prototype:
Of course the GMG attempt was more of a joke, for "entertainment", got that.
Old 10-26-2016, 08:47 PM
  #68
chamilun
chamilun's Avatar
you guys kill me. they did a hell of a job.
"shaking my head the whole time while watching". um, ok
Old 10-26-2016, 08:50 PM
  #69
Flat6Music
Flat6Music's Avatar
There are Porsche purists that enjoy high-performance, and there are high-performance enthusiasts that happen to drive a Porsche. I love my Porsche, but if one thousand hamsters on a treadmill made the car go better, I'd be breeding them right now in preparation for the treadmill swap.
The RUF mill, although a beautiful piece that appears to work well, is still unobtanium. And, sure, a dohc, 4 valve design is a high rpm monster, but what you're looking at us still a six figure (deep sixes) engine. It may as well not even exist when it comes down to wanting one for yourself.
The GM LS series are proven high-performance engines with a vast aftermarket support system with tried and true high-performance combinations (cam/heads/compression/intake/exhaust/injector size/tune, etc.) that leaves little room for error. The recipes for your target horsepower desire are out there. There aren't many secrets in the LS enthusiast community. Guys are eager to share what works best with others that are curious. The LS mills are also proven in terms of longevity, since being first released in the 97' C5 Corvettes.
And the best part? A relatively low dollar per horsepower ratio. And the low-end torque will keep you in smiles that our 996's are incapable of with the M96. Go ahead and build an approximately 500HP/500tq naturally aspirated M96 engine and share your final cost. It won't be pretty, it won't happen fast and won't be in one piece for very long .
The only down side that I've seen so far (and I'm sure there are more) is the final drive ratio of our gearboxes. We're geared a little low for what would be optimal in sixth gear for the v8 conversion. I also wouldn't attempt hard launches with our box either, but that's just me.
Old 10-26-2016, 09:20 PM
  #70
white out
white out's Avatar
While watching this episode, and shaking my head the whole time, I still cant understand why anyone would want to squeeze a Chevy V-8 into the rear end of a German car. Is it even practical from a future servicing of the engine perspective (i.e. can you even get to the oil filter without dropping the engine?). Additionally, what does the Chevy V-8 do to the weight balance and handling. I was disappointed, but not surprised that the "race" at the end of the episode was only straight line, despite having an entire runway. Aaron and Richard appear to be accomplished drivers but, once more, this is only entertainment TV...
SBC? I guessed I missed the mention of the V8 being aluminum. Even if the V8 is an aluminum block isn't it still heavy enough to shift the front to back ratio from the 40/60 stock form?
I dropped my '99 C2's weight down to 2800lbs and gained over 100ft-lb of torque with the LS1 conversion. LS series motors are aluminum block and heads with a plastic intake manifold. Factory tubular exhaust manifolds are available (lightweight.) Engine accessories are mounted low.
Oil filter was easy because it hangs off the bottom of the motor. Oil fill and dipstick were easy. Plugs were MUCH MUCH MUCH easier than any 911. The oil pressure sensor was a PITA to get to.
Old 10-26-2016, 11:15 PM
  #71
RRTEC
RRTEC's Avatar
Originally Posted by mharrison
I have to admit that owning a car and also having a copy of the TV show where it was built would be pretty cool.
That being said, many of the GMG cars are not to my taste, but it looks like Aaron tries to do them right mechanically. I can appreciate that.
I bought a car from a TV studio from a well known show where they build cars and use sponsor products. I basically had to redo everything because the only thing the studio cared about was getting it running. After it fired up on the show it sat in storage. Nothing was bolted down, installed properly, or safely... plus side though I had to build it all over but got a good deal on the parts because it had the best of everything...
Old 10-26-2016, 11:27 PM
  #72
Flat6 Innovations
Former Vendor
Flat6 Innovations's Avatar
Received 2,282 Likes on 899 Posts
Exactly... You can't build a car, or even an engine with a deadline and make it happen without compromise.
Its a recipe for a disaster. hell a shop with a clock in it is a disaster alone.
Old 10-26-2016, 11:33 PM
  #73
dan_189
dan_189's Avatar
Can anyone please PM me a "Discovery GO" account so I can watch it??
Pay TV wont have it here for at least 6 months at best...
Will buy you a Bud light next time i'm in the states to be in keeping with the show!
Old 10-27-2016, 03:00 AM
  #74
Atrox
Atrox's Avatar
Is it a porsh or a por sha please see thread in 996 turbo forum. This thread would shut the internet down over there.
Old 10-27-2016, 03:01 AM
  #75
dan_189
dan_189's Avatar
I'm watching it now, if anyone wants the file let me know
Quick Reply: Gas Monkey LS Powered 911
