996 Forum 1999-2005
Heated seat relay location?
Old 10-24-2016, 01:54 PM
charlieaf92
charlieaf92's Avatar
Default Heated seat relay location?
I'm in the process of troubleshooting why my driver side heated seat does not function. I've determined it isn't the switch, so moving on to the relay. Unfortunately, I can't seem to find it.
After doing some research, it seems that it is somewhere under the seat itself? Could anyone help me pinpoint it? Also, is it possible to remove it without removing the seat from the car?
My car has the memory option btw.
Cheers and thank you!
Charlie
fenley (05-16-2021)
Old 10-24-2016, 02:37 PM
DBJoe996
DBJoe996's Avatar
Received 1,197 Likes on 766 Posts
Old 10-24-2016, 02:41 PM
DBJoe996
DBJoe996's Avatar
Old 10-24-2016, 02:44 PM
DBJoe996
DBJoe996's Avatar
I think Relay 18 in the Relay Panel is what you should check. The Plug is under the seat but not the relay.
Old 10-24-2016, 02:51 PM
DBJoe996
DBJoe996's Avatar
I assume you have already check Fuse Holder A
Old 10-24-2016, 03:46 PM
Ahsai
Ahsai's Avatar
I think relay #18 "Actuation Heating" is for the a/c. In fact, in post #2 bottom it says seat heater 99661852100 and if you google, you will see it's a relay attached to the seat control buttons under the seat. I expect you have to remove the seat and turn it over to get to that relay.
http://www.ebay.com/itm/03-Boxster-P...3D272302492626
Old 10-24-2016, 03:56 PM
DBJoe996
DBJoe996's Avatar
I stand corrected! Thanks Ahsai...I was taking a shot in the dark just trying to help. I don't have heated seats so never really looked into this.
Old 10-24-2016, 04:01 PM
Ahsai
Ahsai's Avatar
I know, Joe. I never looked into that relay till this thread. Learn something new everyday
Old 10-24-2016, 04:03 PM
DBJoe996
DBJoe996's Avatar
https://rennlist.com/forums/996-foru...-not-work.html
http://www.renntech.org/forums/topic...t-wont-go-off/
Old 10-24-2016, 04:25 PM
charlieaf92
Thanks everyone. Sounds like I'm going to have to remove the seat to get to it.
Charlie
Old 10-24-2016, 04:31 PM
Ahsai
Ahsai's Avatar
Maybe you can adjust the seat up to its highest position and take a peek under it first. That relay may be accessible/visible.
Old 10-24-2016, 11:11 PM
Boomvang
Boomvang's Avatar
Just bought a pair of heated seats off a Rennlister, the relay is tucked up pretty far, I would think the only way to check is to remove seat bolts and prop up the front of the seat with a block of some kind.
Old 10-24-2016, 11:38 PM
charlieaf92
Thanks, that's what I was afraid of. Can you describe where its at on the driver's side? For example is it on the outside, inside, towards the front, towards the back?
Cheers
Charlie
Old 10-24-2016, 11:42 PM
Ahsai
Ahsai's Avatar
If memory serves, there are only 4 torx bolts holding the seat to the floor.
Old 10-25-2016, 01:02 PM
Device2
Device2's Avatar
Ahsai, you are correct in the location of the seat heat relay and the seat attaching bolts.
Seat Heat Relay
Seat Attachment Bolts (4)
Quick Reply: Heated seat relay location?
