996 Lifters
How did they come up with bad lifters? knocking noise?
a few here have spent 5 k+ on new lifters only to still have an issue.
is this shop experienced with the 996 motors?
where is the car driven?
I'm always reluctant to question the diagnosis of a pro tech but given the cost of the work one wants to be very sure it is needed.
What are the error codes? What are the symptoms?
If the engine is making noise, not running right. my recommendation is to avoid running the engine any -- if it needs to be run it should only be run under the oversight of a tech during diagnosis -- until the problem has been identified and fixed.
Neither of my Porsche engines has required this level of work. I have come upon one rather new -- in fact it was new when the problem developed -- that had some lifters replaced. This due to noise. (The owner refused to accept the car back after the work.)
I have heard of reports of lifters having to be replaced mainly in cars with VarioCam Plus -- variable intake timing and low/high intake valve lift. In some cases the low/high lift "feature" fails in one or more intake lifters -- due to "dirt" -- and after a road test which confirms this via some observation of the O2 sensor readings and monitoring when low or high lift is enabled by the DME the lifters are replaced.
Porsche guidelines call for all intake lifters to be replaced not just the one. That is if one cylinder is affected, even because of just one intake lifter -- there are two per cylinder, all intake lifters of that bank are replaced.
My 2nd hand info is this is a "new" car problem. The cause is "dirt" -- of which a new engine can have in the form of metal debris that the engine sheds as it runs, and sheds from every internal surface including those of the oil passages/galleys that feed oil to the lifters. My 2nd hand info is this is a rare condition with a mature engine.
Also, again my 2nd hand info is if the lifters need to be replaced this can be done with the engine in the car. The exhaust sytem has to come out along with the rear wheels need to be removed. (My Boxster was in for what proved to be a bad VarioCam solenoid and actuator and this repair requires the cams to be removed and this exposes the lifter buckets which can be removed if necessary and this was done with the engine in the car.)
Unless my info is wrong -- and that is possible -- removing the engine is unneccesary but a shop may prefer this as it does make access to the camshaft covers, and all the hardware under the covers much easier.
Still the tech when he did my Boxster didn't complain about the access and the job -- done I forget now but 30K or maybe closer to 50K miles ago -- appears to have been done right. No leaks. No further error codes. Engine runs just great.
I have done the lifter job as part of full engine rebuild. There is a lot in Search on this subject.Get the latest part 3 Interchange to save on the parts - no need for the Porsche printing on the packaging.
If a lifter has failed, you may find the tappet hammered into the bucket.It requires tremendous force to remove the jammed tappet. Certainly nothing some snake oil like Seafoam/Rislone would achieve.
My jammed lifters were perfectly clean.Examined under a lens and dismantled- everything looked perfect- even the tiny oilways. So the cause is a mystery. It does not seem associated with over-rev but perhaps a combo of excessive heat/revs/old oil ? Nobody I have read & has dismantled jammed lifters has ever found dirt.But the oilways are very small so perhaps...? The lifters that have 'collapsed' (not my case) are the ones where the tappet has worn or the seal/ball/spring has failed. That could be dirt related?
Whatever you do ,do not give this job to someone who has never done an M96. This engine is way more demanding than your average small block V8 !
Just checking if you can verify that this can be done without engine removal?
It makes sense to me, having done this a few dozen times, but on front engine cars.
I was also told by a top-notch Indie in town, that the engine must be removed to do the lifters due to lack of access.
Would love to do this myself without dropping engine.
Once you drop the engine, you might as well change out all those other thangs -- SAI, IMSB, clutch, tranny fluid, on and on into the "while you are there" money pit.
Super User
I think there is a fairly recent thread about someone doing this with the engine in the car, he was having timing issues I think.
I know what you mean I think this all the time about people trying to do stuff with the engine in or paying loads for easy jobs like coil packs and AOS etc
I'm taking my engine out over the winter to do the flywheel and a few other bits and I'm going to YouTube it and post to show its not that hard, it's half a day and like you say you can add that to my job by leaving the motor in the car and lots more frustration.
Once it's out it is so easy to do stuff!!
