***Install aftermarket head unit in MOST car WITHOUT removing factory amp***
#136
So I apologize for a dumb question, clearly audio isn’t my strong point
With the RCA adapter, can you run audio from your phone through the adapter and remove the head unit completely?
Local radio here is mind numbing, I like the idea of a consol delete and take the head unit out as well.
Any feedback appreciated
#138
I'm not looking for perfect sound (I like the sound of the engine more!), I don't use the car for really long trips but listening to Sirius is about all mi after, so piping it through my phone would be perfect.
#139
I just used the iPod directly to make sure the MOST box was working, not while running the car so I don't want to mislead you. However, the sound quality I felt was much better than stock and I'm very happy with my aftermarket head unit that has all the bells and whistles :-)
#140
Sound quality was better than stock on my car, I am using Alpine HU, and mostly Pandora. luv the blue tooth to use the hand free phone
#141
Thanks for the info, I was asked in reference to the sound quality of connecting direct to the adapter without a head unit. I'd like to run a system without a head unit if I can
#143
#144
Sound quality with no head unit is just as good. If you have a good mixer program on your ipad / android device you can tune the system very well, even better than a head unit can produce in some cases. The RCA signal will be no better / worse coming form a HU vs a tablet / phone.
#145
I have tried two MOST boxes and two head units and pop is still happening.
#146
I am getting the power from ignition orange wire as mentioned in this tutorial https://cai-store.com/pages/911-boxs...din-conversion . Also I am using ground from harness, I have also tried grounding it to the chassis directly and it still pops. What would be another good source for switched power?
#147
#148
I've been away from this topic since I bought my Cayman, two years ago. I was under the impression that the $695 MOST/HUR interface was the only way to not have to replace all of the speakers in a Bose setup.
Just came across this thread, today. I like the idea of being able to restore the car to factory, without any cut OEM harness issues. I wouldn't mind dumping the Bose fibre amp, but having to replace all of the low-impedence speakers is just one step too far.
I bought the Longate MOST adapter from Aliexpress, chaining their coupons, for a delivered cost of $88. For that, I can experiment and not be too bent out of shape if it fails to work.
#149
