996 Forum 1999-2005
Found out why muffler was noisy
Old Aug 20, 2016 | 08:01 PM
roadblock's Avatar
roadblock
Default Found out why muffler was noisy
Purchased car year ago sounded good then louder as months went on - purchased new set
As a Fister upgrade is to happen- then all of a sudden car sounded like a total POS and here is why
File Type: jpg
File Type: jpg
File Type: jpg
Old Aug 20, 2016 | 08:05 PM
roadblock's Avatar
roadblock
They gutted the muffler - now it's much more mellow tone - I wonder what other fun I will run into
Old Aug 20, 2016 | 08:33 PM
RRTEC's Avatar
RRTEC
Wow!
Old Aug 20, 2016 | 09:23 PM
Woodman71's Avatar
Woodman71
Holy cow. Do they use salt on the roads where you live?
Old Aug 20, 2016 | 09:54 PM
roadblock's Avatar
roadblock
car is from California - modified Mufflers LOL OR GUTTED is the mod
Old Aug 21, 2016 | 02:01 PM
Cuda911's Avatar
Cuda911
Yeah, all that sand in the muffler can make it sound like crap.
Old Aug 23, 2016 | 02:21 PM
alpine003's Avatar
alpine003
You can easily see that muffler was modified by the non-factory weld at the top.
Old Aug 23, 2016 | 02:26 PM
5CHN3LL's Avatar
5CHN3LL
That weld looks as good or better than any factory weld on any Mercury vehicle I ever owned.
OP, I'm not sure I understand the scenario. Did you purchase new mufflers and find that they were gutted? Or did your already-gutted mufflers somehow grow louder over time?
All of the sudden I'm feeling like a very accomplished grinder and welder - that thing looks like a dragon pissed weld all over it.
*edit* Oh, crap - it just rotted away, leaving a huge hole in the muffler? That's insane. The "Now it's more mellow" means with the new Fisters installed? I would imagine going from effectively no muffler to ANYTHING would sound better.
Old Aug 23, 2016 | 03:00 PM
sweet victory's Avatar
sweet victory
Do people do this mod to pass a visual inspection for smog? Would a nicely made delete pipe/kit not also pass visual or do the gutted mufflers still keep the tone down?
(Haven't lived in CA long enough to do a smog test)
Old Aug 23, 2016 | 03:07 PM
5CHN3LL's Avatar
5CHN3LL
There is a visual inspection; however, mufflers are not emissions equipment, so there would be no issue with using muffler delete pipes. Cat delete pipes, on the other hand, will net you a fail.
In the case of this badly holed muffler, the car would fail smog if the tech happens to use the sniffer on that muffler's exhaust tip because the sniffer computer will detect that the products of combustion are not present in the expected quantities. If there's an exhaust leak, the sniffer can't know if it's before or after the cat - so the car will fail.
Old Aug 24, 2016 | 11:13 AM
roadblock's Avatar
roadblock
Originally Posted by 5CHN3LL
There is a visual inspection; however, mufflers are not emissions equipment, so there would be no issue with using muffler delete pipes. Cat delete pipes, on the other hand, will net you a fail. In the case of this badly holed muffler, the car would fail smog if the tech happens to use the sniffer on that muffler's exhaust tip because the sniffer computer will detect that the products of combustion are not present in the expected quantities. If there's an exhaust leak, the sniffer can't know if it's before or after the cat - so the car will fail.
the mufflers came like that - when I had the car aligned the tech pointed out non factory weld also a rattle noise coming out of muffler HA - And the car passed Wisconsin emission test BONUS - fellow rennlister gave me a heads up on set of mufflers for sale in Chicago and bazinga bolted up perfect - adjustment made for techart tips - fortunate I have tools to cut and make adjustments
Old Aug 24, 2016 | 01:51 PM
5CHN3LL's Avatar
5CHN3LL
Were both mufflers that bad? I'm surprised the sniffer detected enough emissions to pass the car - in CA, the systems are clever enough to know when the probe isn't properly installed in a normal exhaust stream...
Old Aug 24, 2016 | 04:07 PM
Wickedgood911's Avatar
Wickedgood911
Enjoy the Fister modifications, it is a very worthwhile upgrade.
Old Aug 24, 2016 | 07:17 PM
roadblock's Avatar
roadblock
have not checked other side - just needed to get rid of noisy muff first - this winter I will break down exhaust - get the headers ceramic coated put in new coil packs - aww you know - just killing time during the dark times -
Sent from my iPad using Rennlist
