996 Forum 1999-2005
My C4s dyno chart
Old 06-27-2016 | 05:45 PM
Rvca3112's Avatar
Rvca3112
Default My C4s dyno chart
So I put the car on the dyno to see how she was doing power wise. She made 299.3 wheel horse power and 254 torque. Relatively good power although it sucks it didn't break 300 by .7 horsepower. My only concern is the 5th gear shift. It seems scattered. The tech suggested maybe my clutch was slipping. The clutch/rms were replaced at 80k. Ims bearing done at 121k I'm now at 129k. Seems a bit premature. I'm not a professional manual TRANSMISSON driver but I don't know what I'm looking for for signs of slippage. I had the oil analyzed to make sure it wasn't anything bad, and black stone said my oil is near perfect. Any ideas guys?
Old 06-27-2016 | 05:55 PM
Rvca3112's Avatar
Rvca3112
Mods are ipd intake plenum, gt3 throttle body, evoms I take, fabspeed mufflers, evoms tune, rss motor mounts.
Old 06-27-2016 | 05:57 PM
Macster's Avatar
Macster
My 2nd hand info is the dyno run doesn't involve shifting at least under power.
The dyno rollers are started spinning with gentle acceleration maybe starting out in 1st gear and going up through the gears shifting at lower RPMs than one would shift at on the road until the tranny is in the gear desired for the dyno pull. This wants to be the gear that is as close to 1:1 without being under. One wants to avoid any torque multiplication by a lower gear ratio than 1:1.
However, IIRC the 996 gearbox doesn't have a 1:1 gear. 4th is under 1:1 and 5th is a bit over 1:1. So 5th gear I believe should be the gear you use for the dyno pull.
What probably happened is when you shifted the rear tires spun a bit on the dyno rollers.
Old 06-27-2016 | 06:17 PM
Rvca3112's Avatar
Rvca3112
4th gear ratios are 1.22 and 5th is 1.02. We utilized fifth gear for this pull.
Old 06-27-2016 | 06:30 PM
Flat6 Innovations's Avatar
Flat6 Innovations
Former Vendor
The way the plots flat lined, either the engine is out of air, the ignition is seeing safety retardation, you have a bad knock sensor, or the clutch is slipping.
Those plots are too jiggly for me, looks like the ignition is scattered. I'd change the spark plugs.
Old 06-27-2016 | 06:36 PM
Rvca3112's Avatar
Rvca3112
Jake I just had the plugs changed about 2k miles ago. I have been getting a misfire in cylinder 1 and 6 lately. Maybe coils? I was hoping for a more linear graph than this.
Old 06-27-2016 | 06:38 PM
Flat6 Innovations
Former Vendor
MAF...
Does this engine have a cold air intake of some sort? Maybe a K&N unit?
Old 06-27-2016 | 06:46 PM
Rvca3112's Avatar
Rvca3112
It has a evoms intake.
This is a video of the dyno
Old 06-27-2016 | 06:52 PM
Flat6 Innovations
Former Vendor
Figured so. Do you still have the stock intake?
You might try an OEM 3.8S intake.
Those squiggles are text book.
Old 06-27-2016 | 06:53 PM
Rvca3112's Avatar
Rvca3112
I still have the stock Intake. I'll put that back on if you feel that maybe help out with the smoothness of it all.
Old 06-27-2016 | 07:11 PM
Arch1t3ct's Avatar
Arch1t3ct
Very interesting results. I think I have the same intake in my car so I'll be very curious to see what the findings are here. This is not just a smoothness issue - your engine/powerband hit a wall around 6400rpm that shouldn't be there.
Old 06-27-2016 | 07:13 PM
Flat6 Innovations
Former Vendor
Try it and see. The 3.8S trumps them all in my experience. My wife set all 5 of her speed records with the 3.8S, the car picked up 3 MPH once I got rid of the same unit that you have now. Dataloging MAF voltages was the only way I figured it out.
Old 06-27-2016 | 09:30 PM
Rvca3112's Avatar
Rvca3112
3.8 s intake ordered. I'm having cats installed on he car now so I'll leave this intake on and do a after dyno run to see the difference with the cats. THEN I'll install the 3.8s intake and see how that plays out afterwards. I'll keep everyone informed about this as it progresses. Thanks Jake for the knowledge/advice.
Old 06-27-2016 | 09:46 PM
AWDGuy's Avatar
AWDGuy
where would one buy this intake?
Old 06-27-2016 | 10:27 PM
dan_189's Avatar
dan_189
Ebay or even the dealership perhaps?
