Power Steering Hose Fittings
I'm in the process of ordering a whole bunch of parts after dropping the engine. During the process, those terrible power steering line fittings rounded out - the ones on the hard line side are the parts that are bad and they're definitely removable/replaceable but I cannot for the life of me find a part number for them. Anyone have any guidance?
Have you thought about used?.....and cannibalize the part for what you need? Any of these help? I know they are not for a 2002 C4S but I can't think that Porsche would change fittings.
http://stores.ebay.com/Quality-Porsc..._sid=853166208
the picture you posted looks like the one from an old thread here. I suggest you give Pelican Parts a ring if you can order just the fitting or if it is part of the hose/line. Check out FIG 8 in DIY link below:
http://www.pelicanparts.com/techarti...ngine_Drop.htm
Best of luck
Best of luck
I'm in the process of removing the engine in my '03 Targa and having a devil of a time to loosen these power steering connectors on the right (upper) side of the engine compartment. Are there special tools or a trick in getting these apart. I can't get wrenches on the hex's due to space...trying to use crow's foot wrenches/extensions/ratchets but not having much luck...any suggestions? Thanks in advance...
Yep some of the soft touch prices are crazy! Left or right upper dash vents... $850 each, drivers side door sill $985...
