Discrepancy between dip and electronic oil level measurement
Till recently I got quite consistent readings for the oil level between dipstick and electronical gauge. Especially at the higher levels both dip and electronic were almost spot on the same. At the lower side the dipstick indicated slightly lower levels, but still comparably close.
Some 2 weeks ago I got an X51 type oil pan installed (ordered via Brombacher) together with a switch to Motul 300V 5W40 (Xcess 8100 5w40 before).
Car also got a new suspension. Which dropped the car a lttle bit. Front 4-5mm extra then back.
Since then the consistency between both oil level readings is not anymore what it used to be.
For example today I pulled over at a gas station and waited 5 minutes. Car was level. The engine was hot. The electronic reading was 1 bar below max. the dipstick showed almost at min level (lets say around 1/4 between min and max).
Are both measuring systems located at a different place in the sump? Could the X51 pan influence one or both measuring methods?
Received 1,171 Likes
I would say from a logical perspective that the deeper oil pan will not change the max/min level of the oil, it only increases the volume of oil. I have always found no discrepancy between the electronic reading and the dipstick level, however, I have heard of such. Since the engine was hot, perhaps the circulating oil had not had a chance to drain back to the pan so the dipstick was showing low. The electronic reading is not 100% accurate, I take more like "there is some oil in there or it is low." I always depend on the dipstick and only after the car has been run and then has sat for at least 30 minutes.
I don't trust my digital reading at all. It seems to vary where as the dipstick stays very consistent.
The two systems are not in the same place. Ideally the best place is in the center so any out of levelness will have the least amount of effect on the reading. But both the dipstick and electronic sensor can't be located in the same place and the other engine items both outside and inside the engine also have to be taken into account. So both may be located sub-optimally and this not only can account for different readings but possibly wildly different readings too between the two systems.
I don't bother using the dipstick that is in the Boxster but with the electronic oil level system the oil level readings are different if the car is not level. With the car parked straight on a very slight up slope the level is down maybe a bar. The same amount of tilt to either side though has a greater effect. I seldom park with car on a down slope and I don't like to back in a parking space just to take a reading with the car oriented 180 degrees opposite to see how this effects the oil level reading.
The Boxster has no restriction on the car's degree of level. I could probably check the oil with the car upside down. But in the case of the Turbo it is pretty sensitive to how far out of level the car is. This suggest to me the oil level sensor is not optimally located and Porsche seeks to limit the upset varying level readings could have by limiting the reading to only occur if the car is level enough. Since there is a level sensor anyhow to support PSM this is a almost for "free".
Yes. I understand that the absolute oil level is not affected by the deeper oil pan.
Therefore the dipstick should be measuring the same levels as before. Was not sure if the electronic measurement could be confused.
As I said, before readings were both pretty accurate.
I will follow the prescribed procedure to measure with hot engine after waiting 5-10min, i.e. after refueling.
Former Vendor
No matter what the owner's manual says... No matter what anyone says, I NEVER trust the electronic reading until "stone cold 24".... Meaning engine is stone cold and has sat for at least 24 hours on a level surface without being ran at all.
I fight this constantly with customers and their oil levels, and have learned that the oil takes too long to return to the sump for the gauge to be accurate as described in the owner's manual.
Look for The Knowledge Gruppe to publish a directive about this in the near future. People are over filling engines and causing oil consumption issues over and over again.
It's not rocket science and it's very simple. There are two factors that affect the oil level.
1) Whether most of the engine oil has drained back to the sump
2) The temperature of the oil. Oil expands when hot. From 70F to 220F, the level will rise close to 1/2 quart (since we have ~9 quarts)! Between the 'min" and "max" marks is only about 1.25 quart on the dipstick.
From the above 2, you can logically conclude that the only consistent way is after a drive (engine fully warmed up), leave the car parked overnight to let most of the oil drain back to the sump. Then check the oil level in the morning. (ambient temperature differ for tens of degrees at most so oil expansion/contraction is negligible).
Former Vendor
I conducted a 3 month study on this over the winter. As soon as June rolls around I'll do another 3 month study in hot weather.
The expansion of some oils, especially Driven DT40' and Motul 8100 can skew the readings even more. Also, oils like DT40 are very clingy and still to the upper end components longer.
People are adding oil to the genes that appear to be low, and then over filling them. It's happening every day, this is why the 9a1 engines check the oil while the engine is running, much like an Aircooled Porsche.
I also tell my customers to keep the oil level in the middle of the gauge when cold... We avoid filling to the top line of the indicator.
Oops our posts crossed...my previous post was directed to the OP.
It's interesting to know different oil expands at different degrees so that's another reason for checking the level only at ambient temp (assume you don't live in the North pole).
Thx for the insights.
With standard procedure I also referred to dipstickwise. I will keep a close look for the coming weeks what the dipstick tells me about the oil level when either hot or at ambient temperature sitting overnight.
It would sound logical that you want to have enough oil when running hot. As more oil will be splashing/ spraying around somewhere higher in the engine, I mean it will not return immediately back into the sump so more oil will be somewhere circulating while in operation.
The cold oil will be slower to drain from the internal engine surfaces and slower to react to the scavenge pumps so it can be returned to the sump.
Still a hard working hot engine can keep a quart possibly more in suspension at high RPM. Quite a bit of the oil is in vapor form.
I'm careful to avoid overfilling my engines with oil so when I check the oil level cold -- with my Boxster, the Turbo can only be checked with the engine hot (and idling and on fairly level ground) -- and find it down a bar or two I do not top the level up as I know once the engine/oil is hot the level will be higher. I see this when I stop to fill up the gas tank -- after often driving hundreds of miles non-stop so the engine is fully up to tempeature -- and as is my habit check the oil level after filling the gas tank. The level is up.
For the Turbo I check the level and it can only be done with engine up to temperature and in this case if I see the level down a few bars I add enough oil to bring it up to the max line. I prefer to with my cars run the oil level -- hot oil level -- at close to but not over the max line to ensure both engines have as much oil as the factory intended so there is little risk of the engine pulling in aerated oil.
My concern is with a low oil level and under hard cornering and on mountain roads that can have a pretty steep grade too boot oil can move to one side of the oil sump and as the oil level drops on one side the still aerated oil can flow into the where the oil pump pick up is located and the engine can be fed with this aerated oil.
I have come across reports of other engines while being dyno'd having a sudden fall off in power at near red line and this was traced to the lifters receiving aerated oil (due to an adequate oiling system) and this oil compromises the lifters abilty to operate correctly. One has to wonder how this aerated oil affects the main/rod bearings but I guess that the engine didn't spin a bearing or worse suggests the bearings are a bit more tolerate of this aerated oil.
my bet is with-in 10 years ALL manufactures will completely seal the engine/drive train from owner access. i like to think of it as tinkerbell proofing. checking the oil is just beyond some
Former Vendor
To change the oil and filter you zip off a quick disconnect plate, and remove the lube pack, then discard it, and replace it. I have already been part of some developments based around this.
The 9a2 engine is getting close, plastic sump plate, and 1/4 turn drain plug is a reality with those 2017 models. We ordered a plastic sump plate, and within 2 days had a billet aluminum replacement with a real, magnetic drain plug. The OE unit we received was made less than 3 weeks before we received it, and we'd already improved it.
I hate plastic junk.
