Schematics with P/Ns...
When I brought my car in for service in December (right before I put it away for the Winter), I had my car in for normal service and also asked the dealer to check for a bad smell that had just started coming from the HVAC vent earlier in the week. It turned out that a field mouse made a nest in the pollen filter. When I got it home I prepped it for storage and attached the battery tender. I finally had a chance to pull it out last week and when I pulled the battery tender off I noticed that the screw that typically holds the plastic shroud to the left of the battery cover was missing. I'm guessing they forgot to reinstall it after dealing with the mouse crap. Does anyone know where I can find a schematic to determine the P/N for the missing screw? I don't believe it's one of the plastic fasteners and, to be clear, the two fasteners that are attached to the plastic battery cover are in tact.
-Eric
-Eric
I almost felt stupid posting the original ask and, no, I don't need a Porsche branded screw but I have no idea what sized screw I'm actually looking for. lol I'm actually going to be across the street from my dealer next week. I could probably stop by and ask them, too. I just didn't want to make such a big deal over a screw.
And, thanks, but it's not in that pic. When you open the frunk and look at the area below the windshield, it's all plastic, right? That's what I'm talking about. One of the screws that hold the plastic down is missing. I searched around a bit before posting. I can easily find schematics around the major parts but just haven' seen the one I'm looking for.
-Eric
-Eric
-Eric
-Eric
![](https://www.pelicanparts.com/catalog/images/Porsche_Diagrams/9965725670101C.jpg)
It's the other side...but I can probably use that to dig further. Would you mind posting the link to that shot? It's probably the same kind of bolt that's in the middle of the shroud on driver's side. Thanks! I'll do more searching on Pelican's site!!
-Eric
-Eric
http://www.pelicanparts.com/catalog/...ELCHRG_pg2.htm
Eric,
If you look at the autoatlanta link you were sent I assume you are looking at part #12 the screw on the plastic panel that covers the particle filter area (they don't show both covers but the screws are identical. If it is part #12, as a hint, I would also pick up a spare of part #13. The "nut" for that screw. It is a rubber plug with a metal insert. When you tighten the screw it pulls up on the metal plug expanding the rubber to "lock" the screw. They wear out or dry up over time and sometimes it is worn enough that no amount of screwing in will tighten the plug. Then you just leave out the screw, Both parts are cheap and get left out often. I keep a spare of each in my garage.
Received 1,187 Likes
-Eric
-Eric
If you just want a generic screw you don't need to pull the other one. It tells you in the parts diagrams the specs for the screw. It is an M5 x 29, and it has a captured washer.
Ahsai and Krom: Just want to add my "Thanks" as well! The rubber thread thing in my car is shot and now I know where to get it...even if it costs north of $4.00! In fact, per Tharbin, some spares as well.
So, the story continues. I'm wondering how many nuts and bolts my dealer decided not to reinstall after servicing my car. When I got the car back I notice the oil pan skid plate looked a little cockeyed but, in all honesty, I wasn't sure whether I was just imagining things or if I misremembered the way it previously looked. Got a closer look today and sure enough they didn't install on of the bolts! WTF?
-Eric
-Eric
Mine was a dealer "maintained" car that had all of the clips missing from the front plastic underbelly cover. It just had the four nuts holding it on. Just goes to show you don't always get what you pay for.
