996 Forum 1999-2005
EPS roller bearing IMS ???
Old 02-20-2016 | 02:03 PM
GaCoast's Avatar
GaCoast
Default EPS roller bearing IMS ???
Yea Another IMS thing!! Have any of you used or know of anyone who has installed the EPS roller bearing IMS upgrade. This ims looks really good. I'm looking because I have a 2002 C2 with 90K with a dealer replaced ims and associated parts under warranty in 2004. looking at PM things soon, like clutch, rms, imsb, and aos. ?? OH any suggestions for shop in Jax, FL or Savannah, GA?
Old 02-20-2016 | 02:28 PM
Cuda911's Avatar
Cuda911
GACoast, you might start with this one:
https://rennlist.com/forums/996-foru...-oil-feed.html
Old 02-20-2016 | 04:22 PM
Schnell Gelb's Avatar
Schnell Gelb
If you must have a roller bearing(WHY?) - at least get one with effective thrust control from RND?
http://rndengines.com/roller-bearing-ims-retrofit-kit/
There may be an alternative to the RND bearing(they are a distributor so they buy it somewhere else & resell). The bearing sold by RND is a very obscure spec. It is distinctly different from the generic roller bearings offered by others.
You do mean roller bearing? - not deep groove ball bearing??
Old 02-20-2016 | 04:30 PM
GaCoast's Avatar
GaCoast
Thanks for the link! Interesting reading.
Old 02-20-2016 | 04:32 PM
Schnell Gelb
It is a contentious subject among the ill-informed + opinionated. So be careful to find the facts from reliable sources (not me!)
Old 02-20-2016 | 07:22 PM
SFZ GT3's Avatar
SFZ GT3
Don't have a 996 (yet) but have spoken on several occasions with Seth (owner) of Technical Dimensions in Jacksonville. He specializes in 996/7 cars and seems very knowledgeable. He was set to do a pPI for me on a 2003 C2 Coupe that got away from me. I have spoken with other owners her in the North FL area who like him. Give him a shout.
http://technical-dimensions.com/
Old 02-21-2016 | 02:50 AM
Flat6 Innovations's Avatar
Flat6 Innovations
Former Vendor
They replaced the IMS flange, not the bearing.. I am sure of that. Porsche has NEVER had a part # for a replacement IMS Bearing, only the entire shaft. Invoices lead people to believe this all the time.
In 2004 there were no commercially available retrofits, all the efforts that we had were still in development.
Old 02-21-2016 | 08:35 PM
GaCoast's Avatar
GaCoast
Yep, the intermediate shaft (ims) and all associated parts were replaced. A LONG list of parts.
Old 02-22-2016 | 03:53 PM
kromdom's Avatar
kromdom
Looking at PM things soon, like clutch, rms, imsb, and aos. ?? OH any suggestions for shop in Jax, FL or Savannah, GA?
there is some DUDE who is located in Cleveland, GA...he might know a thing or two about P-cars
http://flat6innovations.com/index.php/about-us/location
Old 04-25-2016 | 05:06 PM
Jdubsquared's Avatar
Jdubsquared
5th Gear
Without bringing up an old topic, I've had my EPS IMS for about a 1.5 years and 8k miles on my 2005 997.1S and couldn't be happier. I like the roller design and oil feed with no drop in oil pressure. The design reminds me of the bearings used on treadmills/escalator and the race seems more robust than what is currently offered. I researched this well and felt comfortable in my own research and just wasn't satisfied with other offerings based on real world opinions of several indies I talked to and use for services. By the way my stock IMS was perfectly fine upon examination at 29,800 miles. I had the RMS and clutch done at the same time and both were perfect too. I also, had the water pump replaced bc of the composite impellers at the same time as I thought they may be due to deteriorate based on internet reading. Water pump was perfect too. Though all these are potential issues with the 996/997, honestly, the Internet nay sayers have given what is a decent car, a bad rap. Be sensible with maintainence and enjoy as these will be the last of the "analog" 911.
Old 04-25-2016 | 08:21 PM
Cuda911's Avatar
Cuda911
I was just in a shop last week that was in the process of replacing the IMSB and completely rebuilding a motor due to IMSB failure. They are using the EPS roller bearing. It is a reputable shop. I discussed the roller bearing with them, and they told me they have used it many times in the past with no issues to date.
Old 04-25-2016 | 09:05 PM
5CHN3LL's Avatar
5CHN3LL
Tread lightly, OP. These things have a tendency to go off with very little provocation...
What did they replace it with?
Old 04-26-2016 | 12:50 PM
JayG's Avatar
JayG
I heard they were talking to KK about some low cost bearing he put in his car that worked really well
Quick Reply: EPS roller bearing IMS ???
