996 Forum 1999-2005
First Start Pre lube or not pre lube??
Old 02-24-2016, 01:33 PM
  #61
Flat6 Innovations
Former Vendor
Flat6 Innovations's Avatar
Received 2,288 Likes on 902 Posts
Originally Posted by 993GT
Thank-you for your clarification.
My experience on from simple oil changes to extended sits to fresh build's is the opposite....also not sure how a small air-oil purge causes greater lag then a empty oil canister(large volume) needing filled...basic hydraulics.
With no plugs, there is virtually no cylinder/bearing load and the spin RPM is higher(vs with plugs), while 'light' starting the engine sees much higher cylinder loads and introduces fuel...the only thing seeing a consistent load is the valvetrain, and the pump pushes the same volume per revolutions(ie, not a variable-displacement pump), with some potential lose of efficiency at low rpm
Anyhow, everyone use what they are confident in and works for them...
Cheers,
Don't confuse the first time starting of a fresh engine with what occurs during an oil service.
Two vastly different scenarios. I do more engine builds than oil services!
Old 02-24-2016, 01:38 PM
  #62
993GT
993GT's Avatar
No doubt there, absolutely agree.
Quick Reply: First Start Pre lube or not pre lube??
