Hard start only in an underground garage
Hi guys
I have a particularly strange problem :
1. New battery - tested
2. Good ground strap connection
3. No codes on durametric
4. Car starts on first crank whether hot or cold or warm - any ambient temperature whether sitting for 5 mins or 5 hrs or 5 days - EXCEPT when parked in an underground garage for between 3 to 5 hrs.
Then it requires 3 attempts at key off and key on cranks to start and there are no errors
Open garages are fine
Outdoors fine
Only in deep underground garages - wth is up with that?
Is the car getting insufficient oxygen ?
Outdoors fine
Hi guys
Outdoors fine
Outdoors fine
If (big if) it is dampness I am surprised there are no misfires logged and the CEL is not on. Both of the engines in my two Porsches are affected by dampness, not to the point of being harder to start but to the point of misfiring in damp conditions -- most often a drop in temperature accompanied by more humidity. However, neither engine is reluctant to start.
Provided you are not -- I hate to say this but I must -- imagining this behavior the only explanation I can come up with is dampness which affects the coils and could -- stretching a bit here -- result in an engine less inclined to run.
Agree, or more or less thinking along those lines.
Also if it is that damp its' not really a place I'd want to keep parking at anyway...
Have you had the garage air sampled yet? Is the garage built to code? How are the corners laid out? Was a cornerstone used?
Did you conduct a prestart ritual? Let glow plugs and grid heater warm up enough? Was engine block heater plugged in? Engine blanket installed?
Received 1,184 Likes
Are there steep ramps going down? What I am thinking is along the lines of a weak fuel pump, clogged fuel filter or return line....or somehow the engine is starved for fuel. Next time, turn the key on but don't start. See if you can hear the fuel pump running. Wait for the fuel pump to "prime" and then try to start. Can't be more than the oil level countdown anyway. And...WAG other than aliens have a huge underground powerplant with EMF causing interference..
Here's a stupid question - since you're in a deep underground garage, are you turning your lights on or otherwise adding more drain to the electrical system than you would if not parked underground?
I see from your avatar that you have a cab. Are you putting the top up after the motor is off, whereas you might leave the motor on when putting the top up elsewhere?
There is no reasonable explanation for how an underground garage should affect how the car starts for you, but I suspect there are possible ways that an underground garage could be affecting how you start/treat the car.
I am completely sure it is sun spots
