996 Forum 1999-2005
Air Conditioning Sucks Power
Old Jul 12, 2015 | 11:20 PM
Astro's Avatar
Astro
Default Air Conditioning Sucks Power
Anyone else avoid using the AC because it sucks the power and make the shifting rougher ? It might not be noticeable to those who don't drive it daily, but I sure do.
Old Jul 13, 2015 | 01:35 AM
Macster's Avatar
Macster
Hardly notice the parasitic load on my 2.7l Boxster.
I think something else is going on.
Just a WAG, but have you done an E-Gas calibration recently? Procedure is in the owners manual.
(For my cars without touching the gas pedal turn the key on and leave on for 1 minute. Then turn the key off and leave off for 10 seconds. Done. The times don't have to be exact but they can't be less than the numbers given. IOWs, leaving the key on for 65 seconds is ok. Leaving it on for just 55 seconds is not ok.)
Also, if you haven't had it done in a while do a brake/clutch fluid flush bleed. I had this done -- it was overdue -- for my Boxster a few months back and the clutch action and shift action improvement was remarkable.
Old Jul 13, 2015 | 03:17 AM
Spokayman's Avatar
Spokayman
After I get used to how my vehicles "feel", I can usually detect when the A/C clutch kicks in. Just barely.
But the few HP that the A/C consumes does not affect the performance in any real way.
I agree with Macster that there must be some other issue(s) with your particular car.
Typically an engine's ECU will compensate for the A/C load by increasing the throttle position very slightly when the A/C clutch engages and will then reduce the throttle position when the clutch disengages.
If this did not occur, a person would notice the reduced RPMs, and the engine may even bog down or die. Likewise when the A/C clutch disengages the engine would surge.
Perhaps there is a problem with the switch/sensor in your A/C system that the ECU relies upon for this info.
Old Jul 13, 2015 | 06:03 AM
GNR996's Avatar
GNR996
Old Jul 13, 2015 | 01:48 PM
WalterRohrl's Avatar
WalterRohrl
Interesting, I have definitely been noticing it on mine as well. Will have do try the calibration as suggested above and mine is due for fluid flushes anyway so need to get that done soon as well.
Old Jul 13, 2015 | 11:07 PM
groovzilla's Avatar
groovzilla
just drove my C4S home from SF calif 2 weeks ago in 100-108 degree weather thru redding calif and noticed no difference in power pull at all - 2 days of extremely hot weather with A/C on - i think you have another issue going on
Old Jul 14, 2015 | 12:00 AM
Astro's Avatar
Astro
I don't think it's an EGas calibration issue, since I don't believe the 99's had EGas, it was introduced in either 2000 or 2001 if I recall reading correctly.
Old Jul 14, 2015 | 12:22 AM
Turbojamie's Avatar
Turbojamie
Yep mine too. Pulls way harder and smoother with the AC off. I have tried all the tricks I just think it robs noticeable power. Back in my eagle talon days AC on at the drag strip cost ya 3 tenths.
Old Jul 14, 2015 | 12:51 AM
RRTEC's Avatar
RRTEC
Agreed there is significant parasitic drag with the AC on. My car turns into a sideways tire roaster with it off...
Old Jul 14, 2015 | 10:09 AM
Quadcammer's Avatar
Quadcammer
oh come on. significant parasitic drag? Unless you have a completely botched compressor, it costs no more than say 10bhp to drive the compressor (and thats being generous). If 10bhp is turning a dog into a sideways tire roaster, I'd be shocked. I think you're exaggerating. Either that or you have a more serious problem.
Old Jul 14, 2015 | 10:36 AM
alpine003's Avatar
alpine003
I agree with this however, I think some have a more sensitive butt dyno than others and while hp might be negligible, I think what some are actually describing is the response off the line or in stop and go traffic.
For those of you that wanna be hardcore like me, just run the fan on high with the windows down and get some vent clip mounted cup holders with cups of ice on all the vents. Old school AC.
Or if you need the heavy duty version...
Old Jul 14, 2015 | 11:22 AM
Gator996's Avatar
Gator996
I use a version of that cooler in my airplane. It works surprisingly well!
Old Jul 14, 2015 | 01:00 PM
Macster's Avatar
Macster
Yes, of course. I assumed (apparently incorrectly) we were talking about a car equipped with E-Gas.
While I don't have the numbers recorded my Boxster's A/C system in maintain cabin temperature mode -- that is not blasting arctic to cool down an overheated cabin -- requires less than 1hp at idle. This is based on monitoring engine load -- via the OBD2 port and using a hand held OBD2 code reader/data viewer -- in "real time".
Now occasionally my Boxster appears to get into a perfect storm with the A/C on and while not running full blast still working to bring down the cabin temperature and with the radiator fans on (naturally) (and maybe on high) the engine compartment fan kicks on.
The engine, at idle, begins to labor some. I have not had the OBD2 code reader handy to view engine load at this time. I do not believe this is a problem with the A/C system. I worry more it is either a sign of a battery wearing out -- though the battery does not give any of the typical signs of pending trouble -- or a sign the alternator is getting tired. The alternator is original equipment and the car now has just under 292K miles on it. Other owners have had alternators go out in fewer miles...
Old Jul 14, 2015 | 01:12 PM
alpine003's Avatar
alpine003
This is the official car version used in some classic cars and popular with the vdub crowd.
Old Jul 14, 2015 | 01:28 PM
Astro's Avatar
Astro
All kidding aside, my car drives and feels significantly different when running the AC. The shifting is rougher, and the acceleration is noticeably slower. I agree with 300hp on a car this size you wouldn't think it would matter or be noticeable, but it is. I wonder how much hp the air compressor uses and is this something that could work its way out of whack over the years ? It is after all a '99.
