White smoke / metallic smell
I think I have a major problem. About a mile from home I was under full acceleration, not near redline and looked behind me to see a nice white cloud of smoke. I immediately backed off and basically idled it back home. It stopped smoking unless I accelerated. There is a new metallic smell I am noticing.
No fluids on ground under car or loss of oil. Don't want to start in case it makes it worse.
Anything to check, or should I just get it towed to the shop. #FML, just got it back the other day.
A little more back story. The shop disassembled the left bank (1-3) to diagnose a misfire issue last week. Could this be a problem with the work they did? I worry that even if they diagnose the problem and they caused it that they will make something up to cover their ***'s. Yeah, I'm paranoid, but been screwed before.... Any words of advice here is appreciated.
http://www.oreillymotors.com/porsche/
Oreilly is on the short list, but in Madison and I am near Milwaukee.
As for the problem, since the smoking stopped I am leading towards a clutch disc disintegrating. I've blown engines before and this smell more reminded me of clutch material. Maybe the front differential exploded?
Cars at the shop... Prob be a few days before I hear from them.
'course, if you don't trust the 1st shop possibly having to pay for its mistake out of your pocket at another shop could be the lesser of two evils.
Depends upon how bad the situation is.
I don't think the smoking is from the clutch or a blown front diff.
One possible explanation is the AOS failed.
Another possible explanation is -- since the head was off -- this opens up the possibility the camshaft cover on that head having sprung a leak. I am ignoring a possible head gasket leak as there is no CEL.
The camshaft cover leaks -- if it leaks at all -- under hard acceleration as the crankcase pressure builds and thus forces the oil out between the cover and the head or out around a bolt. There are a number of spark plug tubes that could leak too.
Even though the engine is not manifesting any abnormal behavior, other than the smoking, my advice is to err on the side of caution and have the car flat bedded to your shop of choice to have the source of this smoking ID'd and addressed.
It was random misfires only on bank 1, diagnosed as bad cam solenoid seal (didn't say whether it's the timing one or the variocam one). Bank 1 cam cover was removed and resealed, valve train checked.
https://rennlist.com/forums/996-foru...p302-p303.html
Ok, bare with me.
Engine still runs. Shop bore scoped all cylinders looking for scoring or d-chunk. No physical signs of either. However, there was a small amount of oil and liquid in cylinders 2, 5 and 6. They pressurized the system overnight and found some liquid on the outside of block. Not really sure if it's a head gasket or possibly the crankcase pcv system. I know its called something else, but can't remember. Also, didn't see any cracks on the block/cylinder or anything.
If you have something constructive to share with the shop please share.
Should here more tomorrow.
Ok, bare with me.
Regardless, avoid running the engine any and get the car flat bedded to a shop that can ID the true source of the symptoms.
