Think my 3.6's engine has died :(
![Unhappy](https://rennlist.com/forums/images/icons/icon9.gif)
Chaps my engine is in big trouble. ![Frown](https://rennlist.com/forums/images/smilies/frown.gif)
I was driving at 3mph the other day and it started making this noise:
I've taken it to an indi specialist, who thinks that the bank 2 timing chain has snapped causing a damaged head, bent valves, possible block damage etc....
Its going to be removed next week and stripped, but I've been told it's likely to cost over £7,500 ($12,000).
I'm gutted as I've recently spent £4,000 ($6,000) on it with new suspension, IMS, RMS, Clutch and a X51 exhaust.
The car has a full Porsche history and has done 80,000m and I've changed the oil every 6,000m
I thought if the timing chain had snapped it would not run. What do you think?
Received 1,166 Likes
It might run long enough to increase the multiple catastrophic internal damage of total self destruction. Engines are powerful, even if it only runs on bank 1, while destroying every engine component of bank 2. Sorry for your loss.
Former Vendor
Could be a chain easily. The engine has 3 chains, one for each bank, driven from the IMS and one from the crank to the IMS.
If one of the main chains driving the cams breaks, the engine will run on 3 cylinders, as one side maintains valve timing.
I have master linked timing chains that allow for this work to be done preventatively, but also this allows a repair to be done without complete engine disassembly, which is the case with all other, noon master linked chains. You probably do have ben valves, but the pistons are probably ok. We see more and more timing chain failures today.
Don't even think about starting it up again, you are spreading collateral damage like the plague inside that engine by doing so.
Its easy to diagnose a broken chain, pull the green cam timing plugs and rotate the crankshaft pulley by hand. If the cams don't turn, the chain has failed, or the IMS has become separated.
Turned out my valve liner had slipped (poss overheating in the past) locked the valve, which broke the head, and damaged piston 5 and the liner. It will cost around £9,000 ($13,500) to re-build with a new head.
So I've managed to secure a low mileage 3.6 engine complete with ancillaries which has had the bores tested etc and is supplied with a warrantee which should get the old girl back on the road for a few thousand less. Also I get to keep the old engine to sell for parts. Can't wait to drive it again.
_________________
_________________
Captain Obvious
Super User
Super User
Take it completly apart and sell what is good. The crankshaft, main bearing carrier and one cylinder head should be easily sellable. Heck if the intermediate shaft is still intact sell that too. Then there are all the accesories too.
Sorry to hear about the engine failure, but glad you have found a replacement motor. I just did that dance a few months ago.
Former Vendor
Did the valve seat fail? I can't tell from the pics, but this is the typical failure when this occurs.
The collateral damage probably hasn't stopped there.. Check that connecting rod for straightness and check the crankshaft for cracks.
