Stan
Mine's been lowered - Bilstein's all the way around. You can take it for a drive whenever you want. Just noticed last month that the fenders have been rolled as well.
Lowering springs really won't make a worlds difference in handling. Maybe slightly, but they're mostly just for the lowered "look." Coilovers however, will definitely improve the handling a lot. With less body roll from the stiffened suspension, you'll definitely noticed the handling in the corners.
I would like to go the coilover route eventually with my 996. I have some on my Impreza 2.5RS and besides good tires, they're the best mod for handling upgrades. I was going to buy springs for the 996, but I've read quite a few post that they can wear out the struts. Maybe others can chime in on that?
Sport springs (aka lowering springs) absolutely *did* make a huge improvement in my 996 C2's handling. I used H&R sport springs and the OEM shocks which were still in excellent shape damping-wise. It also looked much better than the standard US-spec ride height.
A DIY job at very low cost.... but you will need an alignment.
The primary advantage of coil-overs is being able to corner balance your car, adjusting the weight to achieve as perfect as possible weight distribution in a ready-to-race configuration. Driver in car, extra ballast like spare tires, etc out of the car, half tank fuel, etc. It's not really all that applicable for a street car, but people love their adjustable coil-overs that essentially are never really adjusted, even when first installed... Now having good shocks *is* important, as is having shocks that are suited to the spring rates your installing, but the OEM dampers are actually quite good when mated with a bit stiffer spring.
I'd also like to lower mine, but one concern is, if I would I rub on speed bumps or driveway entrances. I had this with my old lowered E46 M3 and my past 991 C2S (SPASM) and it was quite annoying. Right now my 996 is stock and I never scrape, but being 1" lower would be nice.
996C2 with cheap K-Sport coilovers had the best turn-in of any car I've ever driven (Viper on coilovers with 305 front tires, Viper ACR, Murcielagos, Gallardos, Elise, Z06s, STi on Ohlins, etc). The key part is on coilovers, the 996 has a more harsh and direct feel, similar to a Viper or Z06; where I compare a stock 996 ride to an M3. Lowering springs are going to be on the softer side vs. coilovers.
YMMV.
Eh. While coilovers are adjustable, it doesn't mean that they constantly have to be adjusted. I dial the car into where I want it and leave it. The ability to get the car where I want it makes coilovers my personal choice.
Other perks; lowered weight, flat cornering, shocks not bottoming out, easy install, change stiffness, and all new components.
My low 996 didn't scrape or high center, but it would frequently lift a front wheel off the ground. On the other hand, my lowered Vipers and C5 would high center on speed bumps and scrape the nose everywhere.
