looking for a hard answer on IMS issue
#33
Former Vendor
Being informed is the key, too many people buy these cars blindly and get bitten. The guys that know about the issues can protect themselves.
Some people like the truth, but in the modern world there's few of those people remaining.
#34
Thanks!
Paul
#35
Former Vendor
Okay, I'll bite. I'm a long time car guy, reading this board for at least a month now and I don't see any specific checklist for an engine PPI. Do you have one or a link to one? It appears you have basically the most experience out there with these engines.
Thanks!
Paul
Thanks!
Paul
Guess who got the blame? The guy that have the free checklist out to be used.... Me! Tell me what's fair about that?
After that I pulled it. Today we share this in our classes, and instruct technicians further on the procedure.
#36
Okay, thanks.
I guess I will just have to buy one and keep my fingers crossed!
I have been in the electric motor repair business for over 20 years now, and really know a lot about rotating equipment. I can't believe a IMS bearing that started to fail couldn't easily be picked up by regular vibration analysis and trending. In electric motors, you can see a bearing failure a mile away, at the start of degradation, long before it destroys itself. I've never seen vibration analysis on an internal combustion engine using an accelerometer, but I'm sure it's been done before.
I did a search and saw a guy in the PNW did this a year or two back, he posted some vibration spectrums on a Porsche newsletter, I saved it but did not have the chance to read it.
I figure if I get a 996, which I am pretty certain I am, I would look into this and sample other 996 / boxster engines to see if we could find different vibration signature amplitudes / discrete frequencies and then change the bearing out at the beginning of degradation. This would be long before metal was found in the oil filter. You seem to be on the end of this process when the bearing or other item in the engine has gone beyond degradation into failure.
I'm sure this has probably been discussed before, but it sure sounds like a fun project for me.
#37
Former Vendor
#38
Captain Obvious
Super User
Super User
You’ve talked the vendor out of selling it to anyone else so this way no one can get it but you? You are not selling any parts and I totally understand that but, now no one can get an oversized bearing for these engines. That’s terrible! Correct me if I’m wrong but, the way it looks to me is that essentially you’ve set up a monopoly on this part by talking the vendor out of selling it to anyone else. Why would anyone blame the bearing for machining errors or lack of hardening of the reground surface/crank shaft? There are thousands of other engines, from other cars (not Porsche) with crankshafts that need nitriding after they are re ground. This service is offered to anyone and thousands of people use them all the time when they are rebuilding their engines and oversized bearings are readily available for them too. It’s nothing mystical of unusual but the lack of oversized bearings for this engine makes this process useless. By blocking the availability to these bearings probably works well for your business but it totally goes against what gearheads do.
Well, at least the good news is that since Porsche started to scale down their crate engine program, demand for an oversized bearing will go up and someone eventually will start selling them to the public.
#39
Flat6: It sounds like you have it all figured out. I can say that if I had your reply to management in the nuclear power industry (where I work), it would be rejected. They would figure out a way to isolate the vibrations.
If I was in your neck of the woods and I was buying a car locally, it sounds like your experience would be great in having you do a PPI.
But considering I'm not, and the car I buy probably won't be in your area, it doesn't sound like you can help me. If you want to email me your engine PPI checklist, I promise not to sue you.
I guess the fun of getting a new car is learning all of its quirks and what makes it tick or in this case tick tock.
#41
While a chip detector is a fine idea, it doesn't cover all the bases. What would be fantastic is a vibration detector on all the shafts and crank.
It is THE primary instrument to forecast a failure in jet engines, well before the actual failure itself and the resultant shedding of material for the chip detector to see.
That would be awesome.
#42
Former Vendor
On top of that we had to carry out all the R&D to test them, and their optimum running clearances. No one else paid for that, it came out of MY pocket. I have learned the hard way to be selfish and to take care of my own, the IMS Retrofit debacle with all the band wagon clowns jumping onboard was among my lessons.
Development is expensive, I've wasted 4,400.00 in less than one minute before; until YOU do that, you just can't understand. People get all pissy about things, until it's their money paying for the development, and until it's their part thats stolen by someone else and replicated. Today, if I allow something to get ripped off and copied, its my fault, before I expected people to give credit where it was due, and do the right thing. People don't.
I'll have no part of that, not any more. If someone decides to assume the role of engine builder, they better be ready to assume all the bad, with all the good; but few are. They want to say that they built it, until it fails, then its the part's fault, or its my fault. Its never their fault.
Whats unique about the M96/97 crankshaft is it's surface treatment and how it responds to heat treat. Hell, I had to pay to have a crankshaft destructively inspected as just one part of the costs of this, and I didn't mention that it cost the same to have one crankshaft heat treated as it does 112 pounds of crankshafts treated. Try that one on for size during development.
If its not mystical or unique, why do I have attendees from 4 continents traveling here in 2 weeks for my hands on engine rebuild school?
Why do people think they are entitled to something, even when they haven't done anything to help create it? I never understand that.
Hell, when I started building these engines and developing them, I was laughed at. Why would I help those people who laughed at me back then, by developing fixes to bail their asses out of trouble today? I don't play the game that way.
Back then people couldn't see the forest for the trees and today they are a decade behind the leaders, and its only their fault.
#43
Captain Obvious
Super User
Super User
Jake,
I totally understand your point and I get it, business is business and that’s fine. But this battle between the big engine builders (like you) leaves the little guy (like me) with very limited options when I want to fix or rebuild my engine. It really doesn’t help a bit when I see a post where a vendor was discouraged to sell parts to others. If now is the time for others to start developing the parts that you already have then, such is life. I have no problem sharing whatever information I’ll get from my projects but then again, I don’t have a business to run either or deal with competition and the related politics, I’m only in it for the fun. I’m sure you still remember when you did all this for nothing more than fun and all this other BS didn't matter.
#44
Former Vendor
Jake,
The problem is that the "little guys" continue to support these rip off artists by buying the knock off part, when they know it was our design that was copied. The "little guy" thats only concerned with his own wallet therefore ENABLES these rip offs to exist!
If people didn't buy the ripped off part, they'd not be on the market; so in a way its all the "little guys" fault. Bet you never considered it that way, did you? Most don't, because they've not personally been ripped off after they worked to perfect something for a couple years, or more.
I want it to be clear that the company who has made these bearings for us is not in the Porsche industry, they are also not a company that provides parts at a "little guy" level. When working with them we must develop every aspect of the component, right down to all engineering and evaluation.
As we move further and further into the 9a1 DFI engines, month after month we see more of them with issues that we've already developed components and fixes for. I let go of developments for older engines as we move newer and newer, and now that we have 5 years of development in the 9a1, and 4 years of modifying them for customers, I'll let go of more M96 stuff when the time comes. I'll do that as long as it does not create potential liability for me.
I am way too damn mean to be a competitor. When I used to race I'd go to the track with a killer mind set, and thats why I stopped long, long ago. I approach any competition with the same mind set.
I have an old worn out T shirt that says "I didn't come here to lose", and its true.
All that said, I have owned a Porsche every day of my life since the age of 12... I am where I am because I am an enthusiastic Porsche owner thats been blessed with an ability to think of the things well before the other guy does, then make them work. It all started with an old VW at the age of 8, then in 10 years I had 80 cars and had already been in business for 5 of those years.
I was up till 4 am this morning working on a 930 engine, and it wasn't because I had to.
Like I said, if you want to be pissed off, or disappointed with anyone, extend that frustration in the direction of Porsche. They are the ones who did not offer over sized bearings, and they are also the ones that made it so difficult for us to do what we have done, primarily by not releasing specifications and making us have to figure it all out ourselves. That was part of their plan.
#45
Don't sugar coat it Jake, tell it to us straight
