Fuel cap retaining strap
Pelican has a plastic one, with strap by the OEM supplier for $14.25. fuel cap strap clip for $1.00.
Currently, as per Hurdi, I just use the wiper to rest it on.
http://www.pelicanparts.com/cgi-bin/...-329&I1.y=-136
http://www.maxspeed-motorsports.com/..._Gas_Cap_.html[/QUOTE]
You should place this in things you should know about your 996 until today I always let it hang. Thanks
Hopefully for the $140 it adds mucho hp.
Captain Obvious
Super User
Super User
I bet other caps are an exact fit just need to go to the junkyard and start hunting. The cap gasket itself is fairly universal, pulled mine off a Neon. My TDI caps look a lot like the 996.
Easy fix: zip tie. Holds fine, and nobody will see it but you (unless you're one of these fancypants who ponied up for a purty-lookin' gas cap, in which case you'll want to show it off and zip ties will look ghetto).
Get the new cap from pelican ! Yeah - seems at this age they are all breaking ! I never realized there was hook for cable either ! In all my other cars - edge of cap itself has slot in filler door ...
I was talking to Tom over at TC's Garage... he says he sells about 20 of them a week (or maybe he said month). Anyway, looks like the gas cap strap is the new IMSB.
Oh, and I confirmed with him that he can sell it cheaper if you order directly from him, rather than through his Amazon listings.
That's annoying alright. What's more annoying is the plastic hinge on the gas cap door broke on mine today. Of all things. I've never seen anyone bring this up before. Hopefully Krazy glue works. It's a pain to get that metal hinge spring back on too. We'll see if this works or I have to get a real fix.
The first thing that I got rid of when I bought my 2000 Jaguar S-type was the gas cap tether. I thought only the British would be foolish enough to put a tether on the gas cap so that when the gas station attendant let the gas cap drop, the tether was certain to cause the gas cap to scratch or ding the fender. Then, less than a year later, I bought my 2001 911, and imagine my surprise when I saw the gas cap tether. At least with the 911, if you let go of the cap, it dangles just below the wheel well opening and therefore can't scratch the fender. In any event, I used a wire cutter to remove the plastic swivel ring that is attached to the tether, and then a mini pry-bar to remove the plastic push pin that attaches the other end of the tether to the car.
If yours is broken, I would just do what I did and eliminate all traces of it's existence.
Does anyone know if the tether is a federal requirement or something? Because every car I've bought since 2000 has it.
