Does anyone have information on the EPS roller bearing IMS Solution?
#61
Received 2,117 Likes
Subscribing!!!
If I end up with the C4S instead of a turbo, I guess the Flat6 IMS solution should be my next investment (esp. since it's right up the road from me in north GA).
Wait list and price is the only negatives though..
#62
![popcorn](https://rennlist.com/forums/images/smilies/popcorn.gif)
#63
When I was pondering the question of whether to do the IMS Solution or another type of IMS retrofit (My car already had a LN "classic dual row" retrofit in it - but I wasn't sure of the milage - my thought was around 30k give or take 5-10k) I couldn't get the thought of having to do it again at some point down the road out of my head. I figured the extra $1000.00 (for the Solution compared to another product) or thereabout was a reasonable up front cost to put the IMSB issue to bed. None of the alternatives (including the EPS roller bearing - despite their claims) do that, so I went with the "Solution". My gut says that EPS won't come up with any sort of data to back up their claims...
#64
From my point of view I could care less what is patented or not. Does it work? How many are out there? None have failed?
that's what I care about. Don't give a sh%× about some numbers. I'm sure inventors are proud all their work gets them that patent, absolutely! But many customers just simply don't care and just want a proven product.
#65
#66
I've no skin in game, but arguing about something that is in a post a couple of lines down, well, this might help...or not
https://www.europeanpartssolution.co...raded-bearing/
http://www.google.com/patents/US9004766
#67
#68
#71
How about these?
I'm all for choices and unicorns and rainbows, but false advertising is illegal and no one wants the facts or the truth.
We publish generally accepted ratings for all the popular bearings and let people make their own educated choice.
Vertex can't even get their advertising straight. One place it's a 2 year warranty and 12 times stronger:
![](https://cimg4.ibsrv.net/gimg/rennlist.com-vbulletin/1097x1193/12_times_b7a1ca4a88c80af39d96d7d2fe350399404b8c9f.jpg)
or 5 year warranty and 5 times stronger:
![](https://cimg5.ibsrv.net/gimg/rennlist.com-vbulletin/753x474/5_times_e3021f2efdd75b2d766685ef99b608f6d1797c10.jpg)
So which one is it? Making claims without substantiation is fraud.
http://www.copypress.com/blog/false-...and-report-it/
#72
A deep groove ball bearing as currently used in the IMS Retrofit can take up to 50% of the dynamic load in thrust.
A traditional cylindrical roller bearing with thrust control can only take up to 10% of the dynamic load in thrust.
The 6204 bearing used in the Classic Single Row LN Engineering IMS Retrofit has a dynamic load capacity of 2900# with thrust max load rating of 1450#
The NJ or NU204 cylindrical bearing has a dynamic load capacity of 3750# with thrust max load rating of 375#
The custom Single Row Pro (dual row angular contact) ceramic hybrid bearing has a dynamic load capacity of 4000# w/ Thrust or 2000#.
#73
Let me be clear - I don't care for patent numbers. I have never looked for patent numbers while shopping for car parts. Never.
I do care about the data to back up a product. Hence why I went with LNE components in my rebuild.
#74
Guys, I just see that its good that different companies are offering fixes for the problems on these engines.
If I want to complain about any manufacturer; its porsche itself. It did not do adequate testing or build enough safety margins into its designs when it moved to water cooling.
I'm just happy there are options from aftermarket vendors.
#75
Since I'm new to researching this. If a vehicle is taken into a Porsche dealership, what fix do they use or recommend? Is there a standard fix that Porsche uses?
