IMS Solution
Captain Obvious
Super User
Super User
Holy #$% Imre, you as well as me and everyone else here owes JR a ton of respect. Im sure you based your choice of IMSB replacement on his research as did I. Granted it took some digging but there is no way we could have done this without using what he knows.
Why are you giving him such a hard time? I expect it from some of the wanna-be wrench crowd but not you. I admit using others FREE knowledge for my repairs. I choose to do them myself as you do. I knew absolutely zero about the M96 engine before this forum and JR's info. I now feel comfortable pulling and rebuilding the engine as do you. Give the guy some credit.
Im sure there is a way to measure some small HP increase and smoothness but it seems silly at this point.
9 is right next to 0 on my keyboard, fat fingered that one. 2002 996 . . . . also, why all the hate. I'm just happy to have my IMS replaced so I can drive my nearly new 996 as long as I want.
My RMS was shot when Flat6 got the car and it was leaking badly. I'm very happy with the service I've received. They even did a dyno run after the car was put back together.
Here are the pictures if anyone's interested.
https://www.facebook.com/media/set/?...4914693&type=1
'njoy,
awk
'njoy,
awk
And let false information be out there that you refuse to correct even though you know it is incorrect. That is tantamount to saying it is correct in my book.
I must say that the l&n engineering "faultless" tool kit is in no way faultless. The damn little circle clip that it supposedly helps install is a nightmare. Mine broke in 5 pieces on the first try.
They are sending me 5 more free of charge. Hopefully one will go in right. The dual row bearing is a thing of absolute beauty. The silly little ring that supposedly holds it in place? I don't know...
The ring snaps into the groove previously occupied by that hefty snap ring on the much narrower stock bearing. I wonder what if anything at all the puny little aftermarket l&n ring will accomplish.
The $800 dollar "faultless" tool is far from faultless in my opinion. They say there is a learning curve to the procedure. I agree. So how about sending a few more circle clips with the damn kit?
Over 300 Faultless Tools have been sold this year alone, I can count the amount of support phone calls that we've had to answer on one hand.
Take the time to allow the tool to find center before tightening the plate to the bell house. This is the #1 issue that people overlook. Use heavy amounts of light oil on the OD of the bearing and the tapered sleeve, and ensure the tapered sleeve is being used in the proper direction, one side os for extraction, the other is for insertion. If this is installed backward you will break snap rings over and over as the unit will not compress and the clip will relax at the very point where it should be compressed for delivery into the housing bore.
The learning curve is 90 degrees, if any of the above issues are present.
