Blackstone Oil Analysis
#106
Former Vendor
#107
I can't tell there's anything wrong by the sound or oil consumption. I just wish I knew where this metal and black derby found in the oil filter is coming from? And why high levels of aluminum and iron in oil test
#108
I've just bought XP9 form your place/ friends and I will get a free oil test. Thanks for that but I wish I could send them this oil sample now so we can get to the bottom of this, but I was not able to find that service on the RND site. I just want to know what's wrong with my engine.
#111
Former Vendor
#112
the black material could be coming from timing/IMS chain pads
#113
Ok sorry I thought you were burning oil
Dt40 has no place on the track that's for sure - from others who have shared UOA with me and who have changed to a better oil suited for track their metals have really dropped
Even in really tight motors dt40 has shown horrible UOA after track use
You can try amsoil 10w40 AMO premium. Great stuff - give it a shot and do another UOA
#114
That problem existed when I bought the car 2 months ago. We found the same Debry in the oil filter and the aluminum and iron was high back then too.
#115
Former Vendor
"Really Tight" engines are the WORST on the track, tight running clearances shear oil faster than anything. We don't build "tight engines" for the track.
The XP series of oils are what should be used on the track, and its been that way since the very beginning of the Driven/ Flat 6/ LN collaborative relationship.
That said, even when I have a customer screw up, (or not listen) and take one of my engines to the track on DT40, the results don't look anything like that Mario1 posted.
I see several issues with that oil, and I see the same things when oil is aerated, and film strength is compromised due to this. Aerated oil offers little to no boundary layer protection, which is what cams, lifters, timing chains/ sprockets and cylinders/ pistons need most to resist wear.
Mario1, send the UOA results to me, with a summary and Lake Speed and I will try to work on it together. Email to jake@rabyenginedevelopment.com
#116
#117
We never developed DT40 for the track. Its a long life street oil with a superior additive package.
#118
That wasn't my definition of tight engine - I should have said engines that don't burn oil and are broken in - that is what I meant
Curious to see what the diagnosis is here given deep sump pan and airatiion are the issues...
#119
What else could cause aeration? Mario do you have any other bolt ons like an accusump, direct oil feed IMS or anything like that?
#120
Am I close?
