IMS Bearing Replacement DIY by Pelican Parts!
Basic Sponsor
The M96/M97 Carrera engine has had a checkered past when it comes to reliability. One of the weaknesses identified in recent years by Porsche has been the intermediate shaft bearing (IMS bearing), which supports the intermediate shaft on the flywheel end of the motor.
Porsche designed these motors using a sealed ball bearing that is pressed into the intermediate shaft. These types of bearings are typically used in devices like copy machines and other machinery used in dry conditions. In theory, the area where Porsche designed the bearing to sit is supposed to be dry. However, after years of use within the engine, it would appear that oil and contaminants from the engine seep past the bearing seal, wash out the original lubricant, and become trapped inside. The result is that the bearing now operates in a less-than-ideal environment and begins to wear prematurely and may eventually cause significant damage to the engine.
We have spent numerous hours to provide you with the most detailed step-by-step DIY with clear pictures of each step. If you are considering this project, check out the article and let us know what questions you have along the way.
Go for it!
Click here-> IMS Bearing Replacement DIY
Go for it!
Your Trusted Source For DIY and Parts
FREE SHIPPING over $99 click here
Porsche Parts | DIY Tech Articles | Facebook | Twitter | Instagram | YouTube | Promos
888.280.7799 | 6am - 5pm PST
![](https://rennlist.com/forums/signaturepics/sigpic303_8.gif)
Wayne, thanks for posting this. Gonzo seems really happy about it too.
I used many of your parts for the IMSB (and other "while your in there parts") I'm doing myself right now. I reviewed many of your tips and articles and found them to contain great info. Thanks for being a site sponsor.
My only question is who makes the "improved" heavy duty bearing retaining stud/bolt that you use in the Pelican kit? I had to buy your whole kit just to get the HD bolt instead of re-using the OEM one.
Would you consider selling a basic single row kit with:
HD retaining bolt/with nut/o-ring/crush collar
updated flange seal
snap ring
new flange bolts
and let the buyer source his own bearing, any of the fine ceramic hybrids out there? You could even add your own sourced seal-less ceramic bearing to the above and have a really nice basic kit for the single row cars.
updated flange seal
snap ring
new flange bolts
Of course Jake and Charles are now declining to sell their replacements to the DIY market. I have great respect for both of them for the work they have done on these engines, the knowledge they have developed and the products they make. However this decision was very disappointing to me.
I compliment Pelican for the detailed information and DIY instructions for the IMS bearing replacement they provide which appear to be much better than LNE and Flat6 provided.
I would recommend adding the tip to place one finger on the bearing when trying to seat the Spiroloc clip. That would help prevent the clip falling into the case on a missed attempt. Also clarify the orientation (sounds silly, but might as well add to improve) of the K: Short center bolt spacer/L: Long center bolt spacer (for engine with single-row bearing) on Fig 19.
+1 on using a finger to prevent Spiroloc or snap ring from falling in case. Bentley video shows this.
Also, I did not use the "set screw" method. Seemed too risky to me compared to fully locking both cam sets and crank. Impossible for engine timing to move with engine fully locked at TDC and makes it easier to verify timing afterwards.
Not sure why Wayne promotes the "set screw" method, especially if you have the cam locking hardware anyway as shown in pics. Either way, great info and I would recommend someone thoroughly read Pelicans, LNE's, JR's and watch Bentley's before doing an IMSB replacement.
The job is actually very easy if you take your time. There's really no excuse not to do this with all the options and help out there now. It's no harder than a plug change, just takes longer.
Captain Obvious
Super User
Super User
updated flange seal
snap ring
new flange bolts
updated flange seal
snap ring
new flange bolts
Sorry to post this on your thread, but there is another IMSB "solution out there now as well as the LN/Raby and Casper bearing. Pedros garage has come out with their own "solution". It's a forced oil lubricated ceramic bearing.
Unlike Raby's solution which which uses an adapter that connects to the oil filter, Pedro uses an unused oil pressure gallery to source the oil from. Then he lubricates a ceramic bearing with it, instead of LN/Raby's plain bearing.
http://www.pedrosgarage.com/Site_5/T...d,_part_2.html
And if it's any consolation Wayne, I buy all my BMW and Porsche parts from you guys.
What a choice these days.
Oh, yeah, Pedros system is made for dual row, single row and the later 997 single row through 2008.
What's interesting is the 997 single row solution reuses the existing bearing , and adds a pressure lubricated cover, so the case does not have to be split. By adding pressure lubrication to the existing single row bearing, the hope is added life.
The plain bearing is the best solution. I am not sure that a lubricated bearing is better than the sealed one. Ceramic acts differently in the presence of oil vs grease. The film needs enough strength to coat the ***** and prevent spalling of the race.
I agree about the plain bearing. LN's plain bearing with Pedro's oil source would be the best combo.
I don't like the oil filter adapter oil supply of LN. I would prefer to keep the oil filter stock like Pedro's system.
Former Vendor
Several years ago while developing the IMS Solution we robbed oil from that location. The oil is not "just filtered" and is less than 12 average PSI less at all RPM points than the SPOFA location which has the same oil pressure as what the main bearings see.
Robbing oil from that location was just that, and it posed several challenges, including lazy lifters and tensioners on that bank of the engine, which is already at the end of the primary oil system.
There is a reason why it has taken Charles and I years to develop the IMS Solution. The easiest place to get the oil supply was not the best. The only failure that we experienced with the IMS Solution in testing was when oil was being taken from "that" location. If we could have taken oil effectively from that location the cost of our kit would have been greatly reduced, but it didn't make the grade.
There's also a reason why the very first product that Charles and I released was the spin on oil filter adaptor, it was a by product of the IMS Solution development that was already in testing as we had already learned what others still haven't. If they pay close enough attention and have a proper means of gathering data, they will over time.
Remember, the reason why the factory used a sealed ball bearing and did not retain the Mezger design with an oil fed plain bearing (like the IMS Solution) is because there was no high volume, high pressure oil in the region of the IMSB with the M96 design as the crankshaft was oiled through its carrier assembly. Unlike the Mezger design the M96 had all its oil passages cast in to the block, and they were not drilled.
Opinions will vary, then there's data, experience and practical application. The view from the inside is a bit more clear. Eliminate the ball bearing= eliminate the problem.
BTW- Kudos to Wayne for supporting the DIY crowd, that takes much more patience and understanding than Charles and I have, and someone has to do it.
