Blowing Out Radiator Debris
I have a compressor and saw a post relating that a dealer did this for a member. Assuming this can be a DIY, how can I perform this seeming easy task? Thx for replies.
Be careful blowing the debris out. The fins are fragile. I think the only way to clean them is the way GeorgeCo and Hurdi posted. I use the soft brush on my vacuum and then run the hose with the nozzle set on "rain" after I get access. YMMV
Yeah, i definitely wouldn't use high pressure air. I used a hose and a soft bristle brush to not damages the fins.
i also have some extra push pins for when i damage them.
I mention it to the SM so he adds this to the work order as a reminder to the techs though I suspect they do not need any reminding.
There are a couple of points: One is the blowing out will not remove a heavy build up of crud. I had the bumper covers of both cars removed and these areas thoroughly cleaned.
Two: I drive my cars a lot -- easily between 10K and 20K miles per year -- so they are in for service (at least oil/filter services done every 5K miles) several times a year. Because of the frequent servicing the trash gets removed before it requires the bumper cover be removed.
The tech uses an air nozzle to blow from behind/underneath the car through holes/gaps in the underbody panels so the stuff gets blown out the front of the car the way it came in.
I have watched the techs do this more than once and I see no risk to the car, the radiator, the condenser or the other hardware in that area.
I clean them annually:
https://rennlist.com/forums/996-foru...hose-rads.html
At the beginning of the upcoming season, I'll install screens to reduce debris intake.
