Thinking of taking my 996 for it's first DE event...
I have a 951 with some VERY fun DE days on it. I just picked up a 996 and would like to take it to a track day.
Several times in this forum I have see 'it happened to me' threads. Someone goes to a track day and has engine problems soon there after. If memory serves me, the thread I am thinking of diagnosed the problem as oil starvation of the engine.
The track will be the new Kansas Speedway, high banks that the NASCAR guys run flat out on. I'm betting it will cause some serious G's on the long way around the banks.
Is there anything special I can do to prevent oil starvation, if indeed that is the problem?![Confused](https://rennlist.com/forums/images/smilies/confused.gif)
THX!
THX!
A good start is getting the X51 oil pan. However, on a high bank, I don't think it'll be enough. You should consider an Accusump, but only if you want to track the car a lot. Otherwise, just keep the revs low and use a higher gear while on the banking.
Parts Specialist
how about running street tires or just throttle back a bit on the bank - that's a cheap solution and after all - it's a DE...not a race
just a thought, I have not seen any issues locally but we dont have high speed banks
have seen a number of cars cough and smoke because they had too much oil in them..the old thought of "make sure and top it off before my track day" seems to get more people in trouble than I would have thought
Former Vendor
![burnout](https://rennlist.com/forums/graemlins/burnout.gif)
I saw oil pressure fluctuation in T7 (110 degree right hander, flat) at Road Atlanta on pretty lousy street tires (Sumitomo HTR ZIII). However, I was almost as fast through there in the 996 as I am in my 944 turbo racer on R compounds, for whatever that's worth.
Wouldn't banked give you LESS starvation than flat? I mean, you are physically putting the engine at the same plane as where you are forcing the oil, right? X51 "sump kit" is a waste without the rest of the X51 package. It will not help starvation much, if at all.
Exactly what I was thinking. In a highly banked turn the force vector generated by inertia remains the same, but the angle of the car relative to the horizontal is changed. So relative to the angle of the car, the force vector is less.
Just make sure you have sufficient oil to start with and drive it! So many worriers, makes me wonder why anyone buys a 996... you're more likely to kill your engine missing a shift, or spinning out and hitting a wall butt-first than you are to starve the engine of oil.
Don't believe that.
