996 Forum 1999-2005
Intakes- need your input por favor
Old 11-20-2012, 09:50 PM
Slopeslider
Slopeslider's Avatar
Default Intakes- need your input por favor
I know that intakes have been covered many times and there are many that feel that Porsche got it right with the stock intake. Let's put that aside for the time being and help me decide which intake would be the best way to go.
I have birthday coming up and the wifey is going to hook me up with a new intake. Looking at the total picture, I currently have a Fabspeed Maxflo exhaust and will be looking to flash the ECU once I have the new intake installed to maximize the benefit of the mods. Utimately, I'm looking for a bit more grunt, improved throttle response and do not want to degrade performance. I track the car about once a month and feel like the intake and flash maybe just the ticket.
I'm really torn between two vey different intakes. I really like the newer EuroCupGT Twin Intake Kit 996 Carbon Fibre Y Pipe. Very little out there about this one. I have some concerns with the intake not aligning with the air scoop(s) in the deck lid and sucking a lot of hot air. If I go this route, I would add a hole and scoop on the right side for the second filter. I think if I can get the alignment right it would be pretty sweet set-up in addition to being some serious eye candy.
http://www.porscheshop.co.uk/acatalo...tion_kits.html
The EVOMs V-Flow while now where near as cool looking has a solid reputation and appears to more of CAI. It also comes with a dry filter to minimize any maf fouling. I haven't really read negative on this one.
http://www.evoms.com/marketplace/Vie...8DD63F61315%7D
Really torn and appreciate your thoughts on which one to pick.
Old 11-21-2012, 12:19 PM
Slopeslider
Old 11-21-2012, 01:14 PM
pmkazz
pmkazz's Avatar
Save your birthday gift for something of benefit-IMHO..
Old 11-21-2012, 01:33 PM
Hardback
Hardback's Avatar
Throw a BMC filter in and call it a day. and/or... If you're looking for more sound buy a schnell bypass hose and cap. These items will cost under 200. This is what I've run for a couple years now. No MAF issues.
Old 11-21-2012, 01:50 PM
MiamiC70
MiamiC70's Avatar
This +1
Old 11-21-2012, 02:20 PM
b8_rdc
b8_rdc's Avatar
I have a new 996 IPD plenum for sale that would really ad HP/Tq. PM me
Old 11-21-2012, 02:35 PM
jrgordonsenior
jrgordonsenior's Avatar
+1. That's exactly how my race car's intake is setup after testing the Evoms air box on a dyno. We found more WHP with the OEM box, BMC filter, and Schnell orange hose & cap.
The other modification I made is I bought FVD's enlarged throttle body for $335. (+/-) and that also showed strong results on the dyno. The IDP plenums have failed in several independent tests to show any improvement without the addition of a larger throttle body. Then you're guessing was it the TB or the plenum or both. For the money I'd just do the TB and a good flash (Softronic?).....
There's lots of snake oil salesman out there. Caveat emptor...
Old 11-21-2012, 06:39 PM
BruceP
BruceP's Avatar
Let's define "Porsche got it right."
Manufacturers never have the luxury of creating a part with only one parameter in mind. Ever. In the case of the intake, Porsche had to contend with performance, but also with cost, perhaps emissions, and - very importantly - with noise. Most aftermarket intakes wouldn't pass certification for use in Germany because they're too loud. People who say that you can't do better than Porsche did don't really understand what it takes to build a car.
So, as with any mod, you have to consider the possibility that an aftermarket specialist doesn't have to live with the same constraints that a OEM does, and therefore improvement is theoretically possible if different sacrifices are made, such as to noise or manufacturing cost. Your problem then becomes sorting the bogus ones from the properly engineered ones.
I have the EVOMs intake. I also have the IPD plenum, EVOMs exhaust, and a REVO flash. Taken altogether, these things have changed the way the engine runs in a way that I enjoy. I haven't bothered to dyno it. I just know it's a little rowdier, seems to pull harder above 5000 rpm or so, and feels great at WOT.
Personally, I wouldn't bother with an intake unless you were going to modify your exhaust and ECU accordingly. And personally, I'd go with the EVOMs just because of the size of the installed base. But I don't have a shred of evidence to support that. Just like everyone else on this thread
Old 11-21-2012, 07:32 PM
Dennis C
Rocky Mountain High
Dennis C's Avatar
Received 1,493 Likes on 938 Posts
I've spoken with my independent mechanic about this. He tunes and races Porsches and Audis. One comment that I've heard him make is that an ECU flash can be effective with an intake and exhaust mod, but it requires higher octane fuel that we typically see at the pumps here in Colorado. 91 octane is as good as it gets here.
Are those of you with an ECU flash running premium pump fuel, or putting in booster/additive? Just curious...
Old 11-21-2012, 09:05 PM
jrgordonsenior
That's not true. Yes you can get more out of a flash with higher octane if the flash can read the higher octane. Most "street" flashes like GIAC ro Softtronic are set for 91 octane. I get 282 RWHP out of my stock 3.4 with 91 octane gas, open exhaust (stock manifolds), and the larger TB. That's about 325 flywheel HP...
Old 11-21-2012, 09:21 PM
BruceP
BruceP's Avatar
91 here. I avoid ethanol, which it's still possible to do around here.
Old 11-21-2012, 09:49 PM
MiamiC70
MiamiC70's Avatar
But many of those mods, ECU flashing, etc... sacrifice torque for HP or move the torque band up the rpm range. Bueno for a race track not so bueno for the street.
I was going to "mod" my 40th AE and more I researched the more I found the x51 engine I have is about as good as it's going to get. NO plenum, edu, exhaust, intake is going to make it much faster / quicker vs. the $ I would have to put in.
BTW the x51 is an expensive $10k+ upgrade and adds 25hp total.
Old 11-21-2012, 10:20 PM
Dennis C
Rocky Mountain High
Dennis C's Avatar
Good to know...
Old 11-21-2012, 10:26 PM
Torontoworker
Torontoworker's Avatar
snip
Old 11-22-2012, 10:09 AM
Dan@SCB
Dan@SCB's Avatar
What he said! PM if you need one. We are the North American BMC Distrubutor
Quick Reply: Intakes- need your input por favor
