Thoughts on LN .5 & 2 qt oil sump kits
1 Post
Just wanting to hear thoughts on which one to choose as they seem to almost do the same thing (besides the oil capacity) with a large price difference.
Not worth it.
If you're concerned about oil starvation, use a heavier weight oil and install an X51 style baffle. That was my solution for ticking lifters following autocross runs. If you're concerned with oil contamination and breakdown, the 0.5qt won't make much difference - just change your oil more frequently.
That said, if you're adamant about it, the 2qt kit is not streetable - the pan will sit way too low. You're more likely to rip the oil pan off the crankcase before seeing any benefits of the additional 2qts of oil.
I have the .5qt pan, doesn't help much on the track. Just had the 2qt pan installed. The design inside is different from the .5qt. I'll be on the track this mon if the weather is good. I'll let you know how it works out. It does sit kinda low, maybe an inch inch and a half lower. I'll have a skid plate put on.
0.5 quart spacer
From the data I have collected, the 2QT deep sump and baffle does not prevent significant oil pressure drops on my setup.
I don't have experience with the .5QT but have no reason to believe it would do any better.
The data to backup my statement about the efficacy of the 2QT deep sump can be found in the thread below. BTW - this is an old thread man...
https://rennlist.com/forums/996-foru...stability.html
Received 1,156 Likes
hmmmm...2021-2012=? I once had a conversation with someone about something 9 years ago....we picked up right where we left off just like no time had passed between us. It was strange.
Dana Whicker (08-04-2021)
Oil starvation
My car is lowered as well. Just get yourself the protective skid plate. You just gotta be careful what you go over.
Also make sure you upgrade your AOS to the UAOS from Porschetech 3 or you will have oil consumption and smoking problems which could lead to bigger issues. This is important.
Splitting Atoms (08-05-2021)
