Upcoming Service - Too much $$$?
Looking for feedback on cost for some upcoming service I'm thinking about:
L&N IMS Bearing Kit
RMS
Clutch Kit inc refacing flywheel
Air / Oil Separator bellows
Water Pump / New
Gasket / Water Pump
Coolant / Factory
T-stat, Housing & Gasket / Low Temp
Serpentine Drive Belt
Mobil One Oil
Oil Filter
Cam End Cover
Total out the door with labor is 4K.
Any thoughts? Am I missing anything?
L&N IMS Bearing Kit
RMS
Water Pump / New
Gasket / Water Pump
Coolant / Factory
Mobil One Oil
Oil Filter
Cam End Cover
Indy or dealership?
Why "resurface" the flywheel? For all that effort & costs, I'd want (to pay for) a new one. Maybe even a LWFW.
What is your mileage? What about plugs and a brake fluid flush, too?
I don't think you can resurface the flywheel. If it's beat, you need a new one.
That's quite a bit of work so the price seems reasonable. If you need a new flywheel the price will go up by at least $800.
Low mileage (35k) 14 year old car
Plugs and fluid flush probably a good idea
That's funny. "Dress contact surface" is fancy-speak for "will spray liberal amounts of brake cleaner and wipe with a fresh rag". Any warped flywheels I've ever seen are replaced and not turned like a brake-rotor.
![Cool](https://rennlist.com/forums/images/smilies/cool.gif)
I just got mine back from the spa and got :
LNE IMS retrofit
new clutch kit
rms
brake fluid flush
coolant flush
new oil filler tube
new serpentine belt
oil and filter
for $4300....sounds like yours is right on par
LNE IMS retrofit
new clutch kit
rms
brake fluid flush
coolant flush
new oil filler tube
new serpentine belt
oil and filter
Clutch
LNE IMS
RMS
Water Pump
CV Boots
Oil change
Cost me $4150 yours sounds about right.
LNE IMS
RMS
Water Pump
CV Boots
Oil change
This is often done with a air tool & scothbrite pad attachment to throughly clean & prep the surface prior to final cleaning with brake cleaner. Works very well on used, true brake rotors. What you need to keep in mind regarding the flywheel is not only its current condition but it's condition until you have another chance to replace it for free labor! ![Cool](https://rennlist.com/forums/images/smilies/cool.gif)
L&N IMS Bearing Kit
RMS
Water Pump / New
Gasket / Water Pump
Coolant / Factory
Mobil One Oil
Oil Filter
Cam End Cover
L&N IMS Bearing Kit
RMS
Water Pump / New
Gasket / Water Pump
Coolant / Factory
Mobil One Oil
Oil Filter
Cam End Cover
![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
