IMS Bearing Replacement and Car Value
#49
#50
Super Moderator
Ok, I am not a mechanic, engineer or even very bright so explain to me where the oil that is leaking from flange or stud is coming from. Since the bearing is sealed does it come from around the bearing or in it?
#53
Former Vendor
When the bearing fails the outer and inner races become connected by seized *****, at least for a split second...
That breaks the center stud which then falls into the bell housing.. That opens up a 1/4" diameter hole directly into the crankcase through the center of the flange..
Then oil pours out...
#54
#55
Former Vendor
Thank you.. I forgot what compliments were like on this forum.
The IMS Guardian monitors every ferro magnetic component within the engine. It is known as the "Engine Guardian" outside the M96 world where we have developed systems for many other cars and heavy trucks already. Soon entire fleets of heavy trucks will have the technology employed in their engines, transmissions and differentials.
#56
#57
It's been said (and it appears from above that at least one person was convinced enough to preemptively change the bearing) that a leak from the bell housing -which is very common due to RMS leaks- must be investigated immediately in case the leak is coming from a failing IMS bearing. That's superfluous logic considering that a failing bearing cannot cause an external oil leak.
#58
Well I just had my RMS replaced, as well as the clutch assembly and the 1k flywheel. She's not leaking now - but - honestly, what can be wrong w installing the Guardian until I need 50-60 service? I could put the 400 in the bank - let it accrue interest and hope that's enough for an engine later? yea .... I'll sleep better.
#59
I'm still very undecided about this "fix" having heard everything from "if it aint broke don't fix it" to "they will all fail eventually due to inherent design problems with the engine" and "the IMS bearing should be considered a service replaceable part" etc etc etc.
I believe Flat6 are developing an absolute fix, my words not theirs but this likely wont be available until 2014 (awaiting patents) so perhaps good or better news down the road for these cars.
The real problem seems to be that it's almost impossible to detect imminent failure so you either have to get the mod done or just hope that the sun shines on the righteous, and you happen to be such a person!
Bottom line for me right now is that this is a crap shoot! Live long enough and we'll all die of wear and tear, and if we're abused along the way, we'll die earlier........this sems to be true for this bearing also. The "abuse" in this case, according to what I've read, seems to be driving the car too gently as apparently ZERO failures have occured on cars that are raced. I talked to a Porsche race mechanic at Road Atlanta a couple of months ago and he (two separate guys from two teams actually) also stated this.
My car has just about 80k miles on it and the clutch feels "odd" so I'm going to get that replaced, adn while I'm at it, the IMS bearing will go in. I just can't see replacing the clutch and NOT doing the bearing while in there! Flat6 will do the job for around $4k (on a C4) and you get a lot of other work/tests/evals included in the price. I'm lucky, they're in Ga and so am I.
Back to the original question.........for me, I'd pay more money for a car that had a documented professional job done on it. I know from my old car hobby that documented service cars fetch a lot more that those that don't have it. Also, old collectable cars that have had known problems fixed by fitting modern and recognized "fixes" command higher prices.........all of this assumes the prospective buyer knows about the problems in the first place, and that's where you educate these people by providing them links to the various media to help them understand.
I would be prepared to pay more for a 996 that had the IMS mod reather then one that did not, IF the current owner could provide documented evidence that the mod was done by a recognized authority and that NO engine damage had been reported prior to the mod.
Ya pay ya money and you take your choice!
