PSE cutout removal with pics
thanks to jfintexas (many thanks) i was able to figure out how to make my PSE NOT stop from 28mph-44mph. I figured we should have a DIY here as opposed to renntech. Took me about 15 minutes to do it, but that's cause i'm very non-mechanic friendly haha
1) find the relay (under steering wheel, above the fuse box, there is no covering to it you should see a lot of relays)
2) find the one that's pictured below
3) pull it out (wiggle it out)
4) you'll need 2 really small flat head screw drivers, insert them into the edges here, twist to get it open and slide them in more. once you have both sides pulled apart (screw drivers stuck in place) use a pliers to pull it out via the teeth, careful not to damage teeth
5) find the resister/wire u need to cut. it's pictured here.
6) cut the wire on the end closest to you, same as pictured in arrow above
7) use needle nose pliers/tweezers to play/twist pull back and forth till the back wire becomes weak and breaks
Finished product:
you can see half of the orange resistor thingy to the right (half cause it got smashed as i was playing with it to break it off).
8) slide it back into the case, put back in car and ENJOY!!!!
thanks again to jfintexas!!!
Finished product:
Very nice, SubZero...very nice! This will make is so easy for those wanting to do this mod in the future. Day 2 after my mod and loving the sound. My 9 and 11 YO P-Car loving sons noticed the change and says it sounds like a race car :-)
super easy, and when i say if i can do it you can do it... i know ZERO about cars lol. I called the guy above 2 times just to make sure haha, so trust me, you can do it, it'll take 10-15min, and most of all you'll LOVE hearing it.
i drove around tonight windows down in the cold just to enjoy it haha
911h20 (07-28-2021)
This must be for a factory installed PSE? I put one on my '99 996 Cab and by not hooking up the vacuum solenoids and electronics it was in the open/loud mode all the time.
There is another much easier way to defeat the cutout. Simply disconnect the speed signal wire (pink/grey (or white) wire from the plug that the relay plugs into.
