Clank noise from Crank pulley & Lights flicker (video) Help!
#136
Generally a rattle is more associated with the chains and related hardware-although a catalytic converter can also rattle . .A rod knock is pretty distinctice .Since the crank does not appear to have excessive play the IMS has to be suspect .That being the case don't know if it is a good idea to run the engine .
I'm sure I already mentioned this in the thread but the noise only occurs after the engine is warm.
#137
The crank can certainly transfer noises from elsewhere.
When I had my crank at the machine shop, he tapped on it with a hammer and it rang like a bell.
If the noise is not related to the way the pulley mounts up to the crankshaft, then I would tend to agree the pulley is just amplifying the noise from wherever it is coming from, perhaps even from the other end of the crank.
#138
This certainly may be good news because a spun bearing would be a PITA.
#139
If you don't have a stethoscope, take a long screwdriver and press it against the IMS bearing area, cup the other end of the screwdriver around your ear. Hear the noise more clearly now?
#140
I hope it's clutch related .To answer your question on why the IMS is suspect- if the IMS shaft were moving fore/aft and banging the oil pump that could create a strange sound (I think).From my motorcycle days I remember chains doing some wild oscilliations if a sprocket was wobbly .
#142
#143
Will oil spill all over the place? I am gearing up for an engine drop. I will be heading over the harbor freight for am engine jack
#147
Fellas, I think I am going to bite the bullet and drop the motor/transmission. This way I will have access to everything including the ims/flywheel. Don't worry another thread will be created so the forum can keep up-to-date on the fun!!
