engine died, waiting for prognosis
Saturday evening I exited the freeway after about a 20 minute trip from my house to an outdoor car show in Scottsdale. As I rolled to a stop on the exit ramp my idle shuddered and rumbled then stalled.
I didn’t hear any unusual mechanical sounds so I restarted it and drove off the ramp to a nearby parking lot. (100') The engine had little power and stuttered until it stalled and I rolled into a parking spot.
Tried cranking it again and it would not start, now it was making a sound like it wanted to start but a knocking from one of the cylinders. I called for a tow and had it dropped off at Becks European. They are checking it out now.
Hoping for some good news today
’03 c2 with 70k and LN IMS retrofit.
there were a couple of 911 owners that saw I was having trouble and when they heard me crank the engine thats what they said also. fingers are crossed
Nothing confirmed yet but Frank found some plastic timing chain guide material and some main rod bearing material in the oil pan. They are removing the right cam cover this afternoon to investigate further. Either way it looks like a major issue requiring a rebuild.
I'll take the maf fail instead if I could LOL
Parts Specialist
you said no mechanical noises?
why did they drain the oil and look in there?
just wondering how they got there from here...did they rotate the motor? check fuel and spark...I mean its kinda weird but maybe they ended up there...not started
Route66 No update yet. I'll let you know when I get one. Off the top of his head he said fuel pump. I just got my car out the week before for shift cables, so I'm in no rush right now. I'll probably follow up Thursday or Friday to find out.
Hope your issue is solved with minimal effort and only a little $.
