996 Forum 1999-2005
Coolant Temp Acting Weird!
Old 07-30-2011, 02:22 AM
100plus
100plus's Avatar
Default Coolant Temp Acting Weird!
Hi guys,
As some of you may know i recently changed my water pump, Low temp thermostat and expansion tank. Reason i changed all this is, i was hoping to solve the high temperature i was experiencing.
Now, my porky's temp maintains itself at about 82C for the first 30 mins and then shoots up to 100C under city traffic. When i get on the expressway, the only way i can drop the temp is by driving at the speed of at least 120km/h.
I am trying to figure out how can i bring the temp back to 82C. Any ideas?
Cheers
Old 07-30-2011, 11:40 AM
ivangene
Parts Specialist
ivangene's Avatar
fan mod - do a search
this is the reason I am NOT for the lower temp t-stat. The thing controling your temp is the size of the system and the amount of airflow....there is nothing a t-stat does (IMO) to change that. You either need more water, or cool the water off (fans) or it will saturate and hit the mark (at which point POOF, the fans come on)
DUH
Old 07-30-2011, 04:29 PM
100plus
100plus's Avatar
DUH
Even with my fans on, my temp still does not go down. Could it be due to a choke in the system? I recently have seen my coolant in the tank rise to almost the cap.
Cheers
Old 07-30-2011, 04:54 PM
ivangene
Parts Specialist
ivangene's Avatar
you need to decribe ALL the factors:
ambient temp included, and what do you mean the "fans on" ? and still doesnt go down? - if that were the case the fans should never turn off if you just let it idle in a parking lot....??? i doubt that is the case unless you have some very very strange issue....
when you say "fans on" are they on High or Low...are both running and where are you taking the temp...remember the fans are very far from the motor and cool water takes time to get back to the motor and be monitored for temp....
I'm not saying you dont have a problem but I am saying you are not describing it well and not providing all the details nor have you check the system static over time, you are driving up the highway watching your digital temps fluctuate and assuming there are problems...right?
Old 07-30-2011, 05:09 PM
silotwo
silotwo's Avatar
DUH
+1 - temp rating of the t-stat is simply when it will open based on the coolant temp. I assume that opening at 160, meaning coolant begins to circulate fully through the cooling system, the car will take longer to reach the 180 operating temperature.
Old 07-30-2011, 06:21 PM
Ubermensch
Ubermensch's Avatar
I agree with you both that a lower temperature thermostat will not lower overall operating temperatures. Personally I installed one in an attempt to minimize hot spots within the engine prior to the opening of the thermostat. So it's less about the over all temperature and more about trying to minimize localized hot spots but getting the coolant circulating earlier.
-Shawn
Old 07-30-2011, 07:23 PM
chsu74
chsu74's Avatar
It is normal how the car's temp runs. There is just not enough airflow to bring the car's temp down without the fan mod.
Old 07-30-2011, 11:21 PM
fbgh2o
Odd Posts
fbgh2o's Avatar
As stated in previous threads your car's behaviour seems normal for summer driving in the city when the ambient temperature is above 27C. My does the same thing. I have the fan mod and can keep the temperature around the 92C to 95C in city driving.
Old 07-31-2011, 04:59 AM
100plus
100plus's Avatar
When my fans are on, they only come on low at about 100C and high at about 105C on the climate control mode. When the fans are on, i observed the climate control mode for any changes in temp but no changes was observed. This observation was done when i was in the parking lot idling.
Cheers
Old 07-31-2011, 12:15 PM
ivangene
Parts Specialist
ivangene's Avatar
no change? over how much time.... again if they didnt do anything the fans would never go off,,,did they go off?
Old 07-31-2011, 04:00 PM
chsu74
chsu74's Avatar
I get exactly the same readings.
Old 07-31-2011, 04:09 PM
fbgh2o
Odd Posts
fbgh2o's Avatar
Those temperatures are correct, based on the factory manual I posted in the other thread and my personal observations.
At idle in a parking lot is almost the most difficult situation to overcome. The water pump is circulating coolant more slowly than while driving and your airflow over the radiators is solely a function of fan speed and not by virtue of forward motion. My car cools more slowly at idle than while driving..., but I have never timed how long it takes the high speed fan to cool while stationary.
Our cars are very sensitive to heat... The radiators seem configured for open road driving.... I find even in traffic on the highway the car will run a few degrees warmer just as a result of turbulent air from other cars.
Old 07-31-2011, 05:39 PM
Macster
Macster's Avatar
Originally Posted by 100plus
Hi guys,
Cheers
Are you sure the fans are working properly?
Otherwise the behavior appears normal to me.
If the A/C is off then the fans only come on when the coolant temp climbs to 212F (100C). The fans run until the coolant temp drops to 205F (96C).
What I have observed from my 02 Boxster:
06:53:27 - temp at 202.
06:55:08 - temp is 212F. (The fans come on.)
06:56:08 - temp is 204F. (The fans turn off.)
06:56:32 - temp is 206F.
The temp continues to climb until:
06:57:40 - temp is 212F. (The fans come on.)
But the temp remains at 212F until 06:57:58 at which time it jumps up to just over 215F.
The coolant temp remains at this temp for approx. 20 seconds then drops to 212F and continues to drop until at 07:01:33 it drops to 198F.
I just checked and the car was moving during the above.
At 06:53:27 the car was moving at 65mph and had been moving at speeds ranging from 80mph to 30mph starting from 06:47:35.
The above coolant temp climb to 212F to 215F folllowed by a drop to 205F or a bit below continued from 06:47:40 to 07:22:49 at which time I shut off the engine.
Sincerely,
Macster.
Old 08-01-2011, 01:28 AM
white99c2
white99c2's Avatar
My car was exactly the same. I did the fan mod and made sure I used 0w40 Mobile 1. Thicker oil definitly makes the car run hotter, I know from experience. Clean the radiators and get in the habit of sticking the hose in the front bumper every time you wash the car and hose off the dirt on the radiators it helps, I live in Phoenix Arizona it's 105+ F here every day 4 months out of the year.
My car stays cool now and cool means the gauge stays in the zero of 180 and doesn't go past the zero.
Old 08-01-2011, 08:04 AM
100plus
100plus's Avatar
Ok, so if 100C-105C is safe then i will just leave this problem at it is. Anyone can Double confirm?
Cheers
Quick Reply: Coolant Temp Acting Weird!
