Car will not start
Car will not start
I was headed out to go to work this morning and I tried to crank my car and nothing happened. All of the lights and systems come on no problem, but when I try to crank the car nothing happens. The volt meter is reading 10v- could this mean a dead battery? The only thing that makes me think it is not a battery is that when I try to crank I hear no clicking etc. Any help would be great!
It is a 6 speed. Where is the clutch interlock switch? I was looking where the pedal is and there is a switch that looks like it would be used for cruise control( button depressed while pedal is fully up). And is there a way to bypass this?
Search is your friend "Clutch switch"
https://rennlist.com/forums/996-foru...ch-switch.html
https://rennlist.com/forums/996-foru...t-the-car.html
Ok I ziptied my clutch switch with no real results. I have not driven my other car lately and its dead too...FML. I guess I am gonna go rent a car and see if I can go get a battery.
You must engage the clutch all the way. If you're off just a little, you get your symptoms. GL
Without turning on the ignition, and you press the clutch into the floor, do you hear a light clicking sound when the pedal hits the floor? That is the clutch switch. If you don't hear it, then the switch has shifted position. If you hear it click but the car still won't start, the switch may be faulty.
larry
I think the problem is a low battery, probably with a dead cell. It's sometime takes a long time to help boost up a battery by jumping, especially if the cables are crappy. How long did you have the cables on?
Rick
99 996C4
87 944S
Rick
99 996C4
87 944S
It could still be your battery, mine did the same thing a week or two ago. I think if your volt meter is at 10 that means one of your cells is dead, should be 12+. Mine was the same way and it also couldn't be jumped. Got a new battery and now it starts great.
Agreed, Just because the Volts are kinda there does not mean it has the amps to move the starting motor, Call CAA (or who ever) and have them come out and load test your battery or take it to them. If you ask me 10v is too low.
Its always best to eliminate the cheapest things first.
