bolt size from cat to exhaust manif. Urgent
I need to purchase new bolts and nuts, my porsche dealer is charging me 5,11 a piece and 7,66, thats like 76$!!! ishh
what are the size of the bolt and nut so i can purchase them somewhere else
little urgent
thanks a lot!!!
little urgent
thanks a lot!!!
On my 2000 the cat flange does have pressed in studs, I had to drill them out, only did one side. A real PITA. However the PET does show bolts and nuts so at some time they may have changed this. Not sure when or why.
Rick
99 996C4
87 944S
One tip a mate gave me was to cut them flush on the side where the threads were ie the side where the gasket would sit, then drill a pilot hole part way into each stud to relieve a bit of pressure so that they can be tapped out. I might have a crack at doing it that way on the weekend since I have mine to do.
I drilled & hammered out the cat studs yesterday. I experimented a bit and found they were a lot easier to knock out once they were drilled about 80-90% through as per the attached pic. Other pics/details are on my 996 web.
