The IMS discussion thread (Read this first!)
#466
I'm considering a 996 and cannot find any info. in this thread regarding the track record of the European Parts Solution oiled IMS bearing.
https://www.europeanpartssolution.com/ims-bearing-upgrade-kit
Thanks for any help you can lend!
#467
#469
Received 1,166 Likes
Just buy the LN Engineering IMS Solution and be done with it. It is the best, and if you''re going in there to do that, that is the solution. I would venture a guess that no one will way in on the EPS DOF IMS replacement. You can do it if you want to...your car your engine. But the Solution is the Solution.
#470
#471
![popcorn](https://rennlist.com/forums/images/smilies/popcorn.gif)
#472
This link wasn't on the first few pages of the google search I did after posting here as a long time member. The only hit that came up for the EPS is that it's an available option, no duh.
It seems the forum consensus is LMS or you're in the same boat as OE. Got it! Thanks
#474
Tractionless: The EPS is oversize (as all of the IMS bearings are, original or aftermarket), it's not a parts issue. The EPS, as with other aftermarket, are NOT sealed so you need to change oil frequently and using original spec(this is important as it blocks particle sizes which are damaging for the bearing) air/oil filters. Common to keep all bearings(and the engine in total) running for a long time is to keep the engine temp low(on average, coolant well below boiling): clean the radiators out frequently. Cooling can be improved: https://rennlist.com/forums/996-foru...-radiator.html
#475
#477
You need to call your garage as labor is a large part of the job and you need to find an experienced garage. Price for the parts you find online. There was a case recently discussed here where the shop messed up the installation due to lack of experience, basically messing up a fully functioning engine.
(This is my opinion and I used to work with bearings)To answer a question you haven't asked: There is no need for an oil feed, a stronger or different bearing... just a replacement. You don't need a different bearing but it's maybe good mentally if the IMSB scares you.
Best way of doing it is to pop the cover for an inspection first, both of the current bearing and the engine in general. If it's in good condition(no excessive play and turns butter smooth) I would leave it in place but most people would probably replace it anyway.
And also, see my advice in the post above.
#478
Thank you for the response. I reached out to a local shop that specializes in both Porsche and performance/race cars to get an idea on costs. I know it can definitely vary, and want a shop with experience with this. I am taking my S6 there for service after a couple local Indy shops didn't really know the car that well. I would think of changing the bearing mainly for peace of mind. Correct me if I'm wrong, but to accurately check the bearing, you have to tear the car apart anyway and separate the transmission. At that point, wouldn't the labor be close to just changing it? I'm sorry if I'm off on this, I'm just learning about the platform now.
#479
Yes, you are correct that the extra labor of replacing it is minimal once you have it apart enough to check it. These bearings go bad from time to time but if they are good they are designed to last in excess of a million miles. If your bearing is good, you know it's good.....if you replace it with something else you're not sure about the new bearing(or it's installation). As they say "If it's not broken, don't fix it"....or google 'bathtub curve' to understand statistically how to think about it.
#480
Posted this in another thread but will share here for cost visibility; 11/99 build date, service performed 08/2017 with 26,800 miles. Indy ran by Jeff Brubaker of Kraftwerks in north central OH, found on LN's site as a certified solution installer;
Replaced stock dual row with LN retrofit (pending passing pre-qualification checks), replace RMS, AOS, clutch, flywheel, fluids, LN magnetic drain plug, scan service/activate PCM, and install LN spin-on filter adapter.
Total with tax; $3,373.90
Majority of the other components are accessible when replacing the IMS so there wasn't much change in labor, just additional cost for the parts.
The following 2 users liked this post by Billup:
Fracture (06-25-2020),
user 8298308 (06-24-2020)
