996 Forum 1999-2005
Will 315/30/18 PS2 fit a WB 996?
Old 07-16-2010, 07:53 AM
6C4GTS
6C4GTS's Avatar
Question Will 315/30/18 PS2 fit a WB 996?
I am intending to try some Michelin PS2 on my 996 C4S as a replacement for the current Pirellis and was looking at changing from 225/40-295/30 to 235/40-315/30 on the OEM rims. The tyre sites seem to say that the tyres will fit OK and the rolling radius match perfectly front to back so no diff problems but would appreciate any comments from C4S or turbo owners running this size on a 8x11 alloy.
Old 07-16-2010, 08:25 AM
LVDell
LVDell's Avatar
I run 315's in the rear of my Turbo for the track. For the street I stick with 295's.
Old 07-16-2010, 09:32 AM
6C4GTS
6C4GTS's Avatar
Thanks Dell - do you run 235 on the front at the track?
Old 07-16-2010, 09:34 AM
LVDell
LVDell's Avatar
I'm running 245 right now and it's too much tire. Rubs. I will be moving to the 235 next set.
Old 07-16-2010, 11:31 AM
6C4GTS
6C4GTS's Avatar
Is that on a turbo or a GT3 - lost track of what you are driving.
LVDell
LVDell's Avatar
Both
Old 07-16-2010, 12:43 PM
onefastviking
onefastviking's Avatar
I've seen 315's on a NB996, a WB996 should be easy.
Old 07-16-2010, 12:50 PM
6C4GTS
6C4GTS's Avatar
Thanks guys - its the weekend now in Scotland so I have some brakes and tyres to warm up.
Old 07-16-2010, 01:19 PM
stavroskon
stavroskon's Avatar
I have the same problem with my c4s. It's time to change my tyres ans i wonna go with 235 and 315 , so if you ok with them let me know!!!
Old 07-16-2010, 03:01 PM
Pac996
Pac996's Avatar
2007 GT3 stock is 235 front 305 rear on 19s so I figure its good numbers. Since I'm running 19s and the GT3 rolls out of the factory cornering good I might try that. Bought the car used with 235 and 275s on 19s. Hopefully the tail wont be as inclined to break loose wearing the 305's.
Anyway the 235 front is good all around the years. It's the rear that needs softer rubber or wider since it's the area that breaks loose first.
Old 07-16-2010, 05:06 PM
gota911
Newbies Hospitality Director
gota911's Avatar
Dell, if you still don't know what you are doing, there are a lot of knowledgeable guys here that you could have asked about the 245 tire size BEFORE you put them on your car.
Bawhahahahahah!!!!
Old 07-16-2010, 05:36 PM
redridge
redridge's Avatar
Bawhahahahahah!!!!
+1.... though I think he likes the infliction he puts upon himself. Classic case of mod addiction.... ask Ed.
Old 07-16-2010, 05:49 PM
LVDell
LVDell's Avatar
I really should have asked the track experts before I ventured out into untested waters. What was I thinking.
Old 07-16-2010, 08:36 PM
Jim Griffin
Jim Griffin's Avatar
America's Tire web site has a section called "plus size" for tires, that informs you alternate sizes for tires on a particular car.
Old 07-17-2010, 12:21 AM
Pac996
Pac996's Avatar
I think I've heard of the skirt being removed to make more room. It works for sur on other makes of cars and somebody on here did it.
Quick Reply: Will 315/30/18 PS2 fit a WB 996?
